Old 03-18-2011, 09:44 AM   #1
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Dropmember / power rack / steering joints
Does anyone have install pics for a unisteer power rack install with unisteer steering joints on a 60-66 with factory steering colum? Ive been searching but all I can find is manual racks with a 2 piece shaft and I have a power rack with a 1 piece shaft with 2 joints. Thanks !!!!!
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 03-18-2011, 10:21 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Dropmember / power rack / steering joints
I think there are a few in Delmo's Blackbird thread.
http://67-72chevytrucks.com/vboard/s...=444600&page=7
Keith
Convert to disc brakes.
Old 03-18-2011, 02:10 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
This one has a manual rack, like you mentioned, but the concept is the same, and the pinion shaft lengths are nearly identical. This one also shows the mod to the column end to accept the DD joint.
http://67-72chevytrucks.com/vboard/s...=406070&page=4
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-19-2011, 10:56 PM   #4
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
I did it!!!
Old 03-19-2011, 11:00 PM   #5
lolife99
lolife99's Avatar
Looks great!
Did you have to pull the steering column up side the cab a little to connect it all?
Or is there enough movement in the joints to make the connections on each end?
Keith
Old 03-19-2011, 11:20 PM   #6
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
I just let it sit how it was, centered the steering wheel, then started mockup from the lower joint that is attached to the rack, took some measurements on the shaft, then made a double d on the factory/cut shaft. Put on joint then got them to the angle that I wanted then trimmed the supplied shaft. Worked out good! Hope I answered your Q!!! That is my step by step pretty much.
Old 03-19-2011, 11:24 PM   #7
lolife99
lolife99's Avatar
Thanks for the reply.
You answered my questions.
I assume your headers/manifolds will clear also?
Keith
Old 03-20-2011, 12:08 AM   #8
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
I mocked up a set of full lengths that I had on prior to the dropmember. Had to mock up fully inflated cause the header would be lower than the truck... lol... I'm gonna have to ask someone else that has the same setup as me about headers. Probably gonna be block huggers or mid length chevelle headers.
Old 03-20-2011, 01:37 AM   #9
Delmo
Delmo's Avatar
I shortened a 3 speed column about an inch and it worked perfect with 2 joints. i'll get a pic up for ya.
Delmo is offline   Reply With Quote
