Old 03-18-2011, 09:22 PM   #1
2003 silverado
2003 silverado's Avatar
Wood Bed
Has any one thought of using one of them wood bed kits in the Blazer? Lets hear the PROS?CONS
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 03-18-2011, 09:32 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Wood Bed
Cool idea. There'd be some fab work at the front, back, and sides to fit it or you could possibly use one of the overlay style kits....
Old 03-18-2011, 09:48 PM   #3
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
Re: Wood Bed
iI would bedrafty when the top is on. But theres nothing stopping you from putting one over the steel just like a hardwood floor in your house... maby some base boards, crown mouldings...
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
Old 03-18-2011, 10:08 PM   #4
bigpig72CST
Re: Wood Bed
I think that it would be cold and drafty. Maybe lots of exhaust fumes? I would worry that losing the weight of steel would make the truck a little more prone to flex??? It would look pretty sweet though.
bigpig72CST is offline   Reply With Quote
Old 03-18-2011, 10:23 PM   #5
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: Wood Bed
I think Jaros44sr did it. Check out his build thread.
low'n slow is offline   Reply With Quote
Old 03-19-2011, 12:40 AM   #6
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
Re: Wood Bed
I like the idea. It would look good without a back seat.
A person might get away with putting thin strips of wood in the valleys of the corrugated steel floor, to make the floor level. Then lay down real thin boards or thin oak veneered plywood over the top and add the stainless strips. This would keep the noise and exhaust out. How you clean the ends up would make or break the look
Torrey72 is offline   Reply With Quote
Old 03-19-2011, 06:51 PM   #7
kc69
Re: Wood Bed
I bet it would look awsome!! I think an overlay would be the way to go. Any pics out there??
kc69 is offline   Reply With Quote
Old 03-21-2011, 09:09 PM   #8
jaros44sr
jaros44sr's Avatar
Re: Wood Bed
not an overlay...
hardest part is to route out the forward outside to get it to sit level and if you use a '73 and up rear crossmember there is a notch there that the wood sits in and has existing bolt holes that line up perfectly for the metal strips
pics will take awhile
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-22-2011, 12:57 AM   #9
jaros44sr
jaros44sr's Avatar
Re: Wood Bed
underside
SAFETY FIRST
AS usual, off topic
Jim
Old 03-22-2011, 06:19 AM   #10
2003 silverado
Re: Wood Bed
Thats cool looking I have to stop by and see it in person
Old 03-22-2011, 01:59 PM   #11
jaros44sr
jaros44sr's Avatar
Re: Wood Bed
Thanks, couldn't find a steel bed anywhere, about 6 months after I put the wood in, a green one shows up in Jersey for sale...go figure
Anytime, stay on 202 north for about 1/2 hour then make a left at the Wm. Penn Inn, can't miss it, it has thounsands of white lights lite 24/7
SAFETY FIRST
AS usual, off topic
Jim
