Old 03-19-2011, 02:07 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
Holes in roof for teardrop marker lights
I'm sanding my truck (72 Cheyenne Super BB) down to bare metal to prep for body work and paint. In the process of sanding the roof down I found a hole...then another....and then a pattern emerged. 5 sets of 3 holes. One further back, one larger and then a smaller one a little forward of that. The roof is flat and nowhere on the spid does it show clearance/marker lights for the roof. So it's not that (plus they wouldn't have had three holes)
Any clue?
It was under what I assume was the factory primer but was filled in with filler....didn't think they used filler then....
Any info would be appreciated.
Old 03-19-2011, 02:10 PM   #2
Re: need help identifying these holes in my roof
It looks like it had the teardrop cab lights on it at one time. The two small holes were screws and the bigger was for the wire. It looks like it was primed and painted over the original paint.
Old 03-19-2011, 02:15 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the fast response.
Those were some big teardrop lights then judging by how far they are spaced apart.... Guess the original owner liked them. Oh well. Just 15 more holes to weld up and grind (carefully due to heat on the roof skin)
Old 03-19-2011, 02:21 PM   #4
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I had a 70 with those teardrop shaped lights on it and it looked VERY similar to that pattern. I wonder if the Super had cab lights on it? It was an option on the 1/2 ton, wonder if it is the original cab if it is not on the spid? Maybe owner installed later?
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 03-19-2011, 03:51 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
If it had factory lights they would have had a raised puck portion on the roof skin from the factory.
This is definitely the original cab. Vin matches spid sheet, has the bucket seat supports, the hole in the firewall for tach, etc etc...
can tell vin tag hasn't been messed with. And the driver's door matches the vin also.
Just must have been someone that wanted the lights and added them.
Old 03-19-2011, 04:33 PM   #6
STOCKISH
STOCKISH's Avatar
I just looked at the pics again, I dont think the rear hole in my cab was that far back. Cant wait to see more pics of this build!!
--Josh
Old 03-19-2011, 04:39 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Not necessarily true. Not all factory lights were the hocky puck style lights. If my memory serves me right, they did not use those untill 69 or 70. I had a 50th anneversery truck with factory tear drop clearance lights. I still have the lights and harness. They were listed on the build sheet and glove box option sheet for that truck. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-19-2011, 08:09 PM   #8
Fesser
Fesser's Avatar
Can't help on the roof holes but was hoping you would tell me where the hole for the tach goes. I'm wondering if one of my rigs had one.
Fesser is offline   Reply With Quote
Old 03-19-2011, 09:41 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
It's the hole in my firewall picture between the fuse block and e-brake. It will be a round hole if you had it from the factory. If not (as seen in the labeled picture) it will just be a dimple
Here's mine...the round hole between the large square and rectangle on the driver's (right) side
Old 03-19-2011, 09:21 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
b eing that your truck was a 72, it would have the raised mounting pads. Those holes were added by a person after the truck came off the assembly line.
Old 03-19-2011, 09:27 PM   #11
CG
BlahBlahBlah
Maybe it had five of those giant horns on the roof lol.
Old 03-19-2011, 09:30 PM   #12
feller
feller's Avatar
um i could be wrong but i think the "puck" that every one is refering to is actualy a rubber gasket that sets on top of the cab and under the light assembly. the factory lights look to me to be the same from i dont know when untill they changed the body style in 89 for 1/2 and 3/4 and 91 for the crew cabs. also were used on the c/50,60 ect. but i could be wrong.
feller is offline   Reply With Quote
Old 03-19-2011, 09:34 PM   #13
CG
BlahBlahBlah
Cab marker lights at one time were the shape of a hockey puck
Old 03-19-2011, 10:38 PM   #14
Longhorn Man
69 to 87 (or 91 for 3500) had a raised pad stamped in the steel in which the rubber base mounted on.
Old 03-19-2011, 11:14 PM   #15
too much stuff
Roadtrip!
too much stuff's Avatar
Those measurements you gave are correct for the tear drop style light. Should be like what i pictured.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is online now   Reply With Quote
Old 03-19-2011, 11:16 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
Thank you. Mystery solved I assumed it was some kind of lights but you know what kind of trouble you can get into when assuming things
Old 03-20-2011, 01:34 PM   #17
feller
feller's Avatar
OK i stand corected!!!!!!!! it takes a big man to ad mit when he is wrong haha. but for real my dad used to have a 72 c/30 that has the factory firemans hats but some dumb A$$ kid decided to take it to the junk and there isnt a day that i dont regret it any who now that i see pics i remember the raised portion of the roof to keep the lights level. but the set of firemans hats i took off a 73/87 at a junk yard for $5 with wires and bulbs just had holes punched. and i am the only one of my friends that run thie body style all the rest are in to 73/87's poor guys dont know what they are missing. any way thanks for setting me strait all of you.
Old 03-21-2011, 12:54 PM   #18
Mike J
vw guy & now c-10 guy
Mike J's Avatar
Re: Holes in roof for teardrop marker lights
I had the same problem- sanding my roof down and started finding the holes- I was like crap! - you never know what's hiding under the paint...
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
