what are these???
changed valve cover gaskets yesterday. and while i was hosing down the engine bay. i was wondering what some of these things were??
i noticed a line that goes into carb had a little hole in it on the bottom side. never touched it before so i didnt notice. but that was one of the first things i touched. and when i touched it, i felt water, or so i thought. pulled it off carb and noticed it was swollen and gas was leaking thru. i traced the line and it went into a round canester looking thing on driver side. below the lights. dont know what it is. so i looked around and took a couple pics of things i was unsure about. obviously im no mechanic. and lack much knowledge. thanks for any help. ![]() ![]() ![]() ![]() |
Active Member
![]() Join Date: Dec 2004
Re: what are these???
Someone else can correct me if I'm wrong:
1. Charcoal canister for fuel. 2. Appears to be part of your cruise control, if you have it? 3. Looks like your wiper motor. 4. ???
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
charcoal canister.. whats it do?
truck has cruise. dont think it works tho. both things in 3 are wiper motor? my wipers work. but the spray function does not work. not sure if its cuz the arm in my truck that controls the wipers i broke or if its the motor. not sure where the motor is to replace tho. thanks for reply. |
Robert Olson Transport
![]() Join Date: Oct 2002
that thing in picture three is your wiper motor... and the round ball is part of the vacuum for your cruise control.. the charcoal cannister takes fumes from the gas tank and vents em o ut for you
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
regular everyday normal guy
I believe #4 is your air pump, for the exhaust emissions
-Andrew- 1987 Chevrolet V10 SM465 NP208 w/ '89 454 dual plane hi-rise 750cfm 1407 w/ '86 10b /14b new motor on the way: GM#990 heads 25cc speed pro pistons COMP XE 274h crane gold rollers |
your squirter pump for your wippers is mounted to the backside of the wiper fluid resivor and if the switch is broke thats a good reson it dosnt work but the pump probly has corroded and dosnt work ether
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
thanks for replies.
switch is cracked but works wipers. dont think cruise works. never tried. if it does, ill never use it. ill check for the motor for squirters. thanks |
Slots go on anything!
The vacuum reservoir also holds vacuum for your HVAC controls. You want to keep it.
1974 Jimmy- 5.3/4L80e/NP241 |
will do. thanks for reply bud.
you the jonboy with the sweet red truck? |
