03-20-2011, 12:05 PM | #1 |
Gauge Cluster & Tach Question
I understand earlier clusters, 70's, are not compatible to the 80's. Amp vs volt gauge and the speedo, 100mph vs 85mph, appears to be what visually designates the two besides the volt/amp difference and circuit board differences that exist.
Yet my question is this: Can one take a tach and the smaller fuel gauge from the earlier or any cluster and put in an 80's cluster? Would it work? (think 85...I am) Seems there are more earlier tach clusters for the 70's than the 80's I see on ebay, so I'm asking, since I am soon back to taking my gauge cluster out once again to update my dash and interior. If I can just swap out my fuel gauge for a tach and install the small fuel gauge where I have no clock anyway, is this an option, or is that circuit board the master controller? Basically the simple question is: Are the gauges themselves interchangeable except for the volt and amp gauges that are definitely different? Will the circuit board "notice" the difference if I install a tach and a "new" fuel gauge if I leave the other gauges alone? Figure this question is about as clear as mud so bear with me. Mark
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." Last edited by RuralRoute C-30; 03-20-2011 at 12:08 PM. |
03-20-2011, 12:50 PM | #2 |
Getting Old; Going Broke
Re: Gauge Cluster & Tach Question
It's been asked 100 times before, best info you can find to learn up on it all, is: http://www.73-87.com/7387garage/inte...achometers.htm
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
03-20-2011, 12:56 PM | #3 |
Thanks for the link, forgot about that one.
A gray hair moment. Mark
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." |
03-20-2011, 02:12 PM | #4 |
i bought a gagecluster at a swapmeet and it had a tach idk what year of truck its out of but any way i ended up taking the tach and fule gage and i swaped it in to my original gagecluster. it seems to work fine.
cluster from swapmeet my original cluster with the tach and the fule gage. |
04-07-2011, 10:47 AM | #5 |
not to thread jack but where did you get the 140mph speedo
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
04-07-2011, 10:48 AM | #6 |
never mind looked a little closer
04-07-2011, 10:48 AM | #7 |
It's not a MPH speedo, it's a KMH speedo. Go up to Canada.
03-20-2011, 10:47 PM | #8 |
K5Camper
I've installed a volt gauge in my 75 cluster that had an amp gauge in it to start with. I bent back the tabs that the amp gauge used to connect the gauge to the printed circuit. With those out of the way I ran external wires for the power and ground to the new volt gauge. It works just fine.
The only thing I don't like when mixing the early and late versions is the different font to the numbers. Not having them match makes it look like you cobbled it together from other vehicles. It just doesn't look finished. One could fix that by using some type of gauge overlay to make them match.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
04-07-2011, 08:13 AM | #9 |
We could help. What are friends for?
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
04-07-2011, 11:08 AM | #10 |
Slots go on anything!
The mechanical oil pressure gauge was from 73-77, for all trucks with gauges. 73-75 used an amp gauge, 76-77 had voltage gauges, and all used 100 MPH speedometer. Not overly rare, should bring $30-60 depending on condition.
1974 Jimmy- 5.3/4L80e/NP241 |
04-07-2011, 07:24 AM | #11 |
Nothing special. The clocks are getting harder to find, but still some out there.
Anything with a tach in it used to be worth money, not sure what the going rate is now.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
04-07-2011, 03:20 PM | #12 | |
Conversion Truck Addicted
i want a canadian speedo and a diesel tach from a mid duty truck
Thomas Quote:
