350 Turbo with cracked case
Hello, my 78 k10 (full time) blew the transmission(th350) the other day and now has a healthy crack that's spewing fluid everywhere.
I've called around a few places to get quotes on a used or re manufactured TH350, but I feel like there might be another problem that caused the crack in the first place. I did some research here on this forum and apparently there's a tendency for these to crack because of a lack of bracing from the factory? Possibly also replacing all the engine and transfer case mounts? What other things could contribute to a cracked transmission case? I wasn't thrashing the truck at all when it happened, it was just cracked when I went out one morning. The bed is seriously sagging on one side, I don't know if this could have caused any unusual stress on any of the mounts... If I attempted to replace the transmission myself, it would definitely be largest repair job I've ever tackled, but I feel confident I could handle it. I just want to make sure I completely fix the problem when I get in there and not have another cracked case on my hands in 3 months because I didn't replace all the correct parts. Thanks everybody! |
Re: 350 Turbo with cracked case
I don't think it is a lack of bracing that would have caused your problem. Maybe you mount is damaged and that caused it to flex.
If you replace the mounts don;t mix and match rubber with urethane - they should all be the same. Just my .02 cents. |
Awesome, thanks!
I just had this problem with my 7oor4. It seems to be a combination of the motor mounts and trans mount fatigue. I would check the motor mounts and trans mount when you are replacing the trans.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
