03-21-2011, 08:46 PM | #1 |
What chance does a D60 have for 3.54 gears??
I have been searching high and low for a Dana 60 w 3.54 gears for my 70 longhorn. Well today I called on a really nice long bed trailer that I can trade the guy some parts I have for. Turns out it has a D60 and I wonder what the chance is that it has 3.54 gears in it. He said the truck was a 3/4 2wd but did not say if it was a BBC or auto/manual. I know how to find out of course but thought I would see if someone had run across some and had an idea of how many were built with 3.54. And were the BBC auto 3/4 2wd the only ones that had the 3.54s? Thanks
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
03-21-2011, 08:56 PM | #2 |
Grandpa in the rustmobile...
Re: What chance does a D60 have for 3.54 gears??
I dunno but that blue trucks really nice lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-21-2011, 09:13 PM | #3 |
Moderator
i would say there is a very good chance it has 3.54's in it. i believe that was the most common ratio in the d 60's in our trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-22-2011, 06:46 AM | #4 |
I would say about zero chance in a 3/4 ton rear end. Maybe if it did come behind a big block. If it came behind any other engine it will be 4.10 (most common) or 4.56. The D60 semi-floaters that came in a few half tons (6 lug) are mostly 3.54 iirc.
Tim |
03-22-2011, 06:56 AM | #5 |
Watch out for your cornhole !
I had a 72 factory big block 3/4 ton with D60 and 3.54 gears. I've also seen others with the same configuration that various buddies of mine owned. They're definitely out there.
03-22-2011, 11:14 AM | #6 |
Moderator
Same thing I had, and I have seen it in most 3/4 ton trucks.
03-22-2011, 07:19 AM | #7 |
On my K2500 350/TH350 the 3.54s were standard...not listed on the SPID,anyway.
03-22-2011, 10:16 AM | #8 |
its all about the +6 inches
tim, that's an odd ball. A 350/350 in a 3/4 should have 4.10
Going by the books, (not always right) a big block is the only way to get that gear set. Going by what we know, you had to have a dana for that gear, and big blocks/automatic/3/4 ton always got it unless otherwise optioned. We also know a small (almost not worth mentioning) number of inline trucks got it. Tims is the first small block I can recall hearing about with it. With all that being said, you are searching for a rather lame rear end. D60 has a goot rep, but not these ones in the 3/4 tons trucks. The axle shafts (28 spline if memory serves) is weak and likes to shatter. |
03-23-2011, 11:19 AM | #9 |
03-23-2011, 11:27 AM | #10 |
My big block 70 Sierra Grande had 3.54. But my parts 70 GMC Longhorn has 3.73. Visually verified, but it is an open diff and the SPID say s Maximum Traction Diff, so I know something has been changed. I assume an aftermarket install?
I have another 70 C2500 GMC parts truck that was a 6 banger 3 speed originally. Ratio tag is missing from cover, so will be interesting to find out what's inside at some point.
03-22-2011, 10:34 AM | #11 |
Looks like a mixed bag here. I am not woried about the axles as this is just a driver that sees very little work and no bad weather. I am most concerned about the ratio and I will be finding out today I hope. My Longhorn currently has at least 4.56 and it is a bugger to drive anywhere on the freeway and getting this 3.54 ratio would make it a truck that gets used to cruise places a lot more.
I asked the guy if it was a BBC truck and he did not know but is going to look today. Thanks for the input as I was just curious. Thanks
03-22-2011, 12:55 PM | #12 |
I Have a d60 w/3.40 gears from a 71 gmc 3/4 for free if anybody close around to pick it up.
03-23-2011, 11:17 AM | #13 |
03-23-2011, 06:46 AM | #14 |
The guy I bought mine from said it must have 3.73s because it drove so nice at hiway speeds. I thought nothing of it,didn't know any better at the time. I did drive it cross country and agreed it rolled on the interstates nicely. When I serviced it I confirmed it had 3.54s. I've seen a lot of trucks with what should be optional not listed on the SPID. Has anyone else noticed that? I have rarely ever seen gearing listed on any SPID. I don't think the books are wrong. Drivetrain combinations are cast in stone.
I think it's an ideal ratio and just right for these days with fuel consumption being considered more strongly than back in '72. They pull well with a load,yet roll on the highway with ease. I've always wanted the "UMPH!" in my gears and prefer 4.10-4.56s in my 8-lug trucks. I tend to go taller with my tires,also. I'm looking to change my rears to a 4.10 HO52/Dana60 combo due to going to much larger tires. I'm sure the 3.54 set will be a great find for someone when I let them go. The guy I bought the HO52 from about gave it to me (w/No-Spin) after he swapped to a 14-bolt to get 3.73s. These Dana60s are the original axle with the modern ratio for these trucks.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-23-2011 at 11:22 AM. |
