Stripped Lug Nut help
I am changing out my wheel cylinder...the lug nuts on my 1987 GMC sierra are ALL stripped on this drivers side. The lugs on this truck are about 5 different kinds. It has been in the family for a while..haha
I am new to mechanics and have never ran into this problem. I believe they are all chrome capped lugs. I do not want to replace them with the same. So first can you help me get them off so I can finish the job...and pray i do not snap the brake line...and 2...where can i find a good set of lugs (original or not) that I can get a whole set of them to replace all of them. Thanks again for the help! Bill |
Re: Stripped Lug Nut help
I'd say that the chrome caps are just spinning around on the nut. Try maybe drilling a hole in the top of them and prying it off with a screw driver. Then you should be able to get at the nut with a properly sized socket.
My 68 cougar restomod build:HERE Last edited by SeanPaintsFlames; 03-22-2011 at 12:10 PM. |
#3 | |
C35 Crew Dually
if not any auto parts store should sell striped nut remover kit. these have saved my butt several times.
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
You should be able to get a cone type socket at your local auto store. take this and put it on your impact, if you have one, if not try to find someone with one. the cone will heat up and grab the nut and spin it off by friction. been a while since I used one of these, but I remember it worked. good luck
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Thanks...i will go to the store and see what I can get. Here is what I am working with just so you have a visual
NOT REALLY BANNED!
![]() Join Date: Jul 2004
Pull the center caps off. Use a flat head screwdriver to break the flimsy sheet of chrome steel off of the top of the lugnut and you'll see that the skin pulls right off.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
it looks like the socket isnt going on far enough to get a good grip...take the center caps off and try it
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
oldschoolblazer@yahoo.com
thats why I love this Board always a helping hand to help another out
![]() yes i agree take that center cap off then that will allow you to get a socket all the way over the lug nut... |
NOT REALLY BANNED!
It's one of the lugnuts with the chrome cover on it! Split the cap with a screwdriver or chisel. I had the same exact issue! Don't waste your money on easy-outs, lug nut removers and acts of god.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. Last edited by 1BadSS; 03-22-2011 at 08:56 PM. |
#12 | |
I want to replace these lugs on this truck (like 4 different kinds) with all one kind/brand....what can i get that wont break my bank but NOT CAPPED?!? |
18 Till I Die
I would go to your local tire shop. They carry all kinds and are sure to have replacements. They deal with lug nuts all day long...
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
78K & 79C Jimmys
i got some at costco cheap $$
but solid steel chrome nuts not cheap cap covered ones I've hammered on the closest size till it fits, just don't get open ended ones again the stud will rust behind it and make em hard to get off
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#15 |
if that doesnt work buy a socket that is the metric size a little smaller then what you need and put it on an extention and hammer it on the lug...then remove, but i think taken the cap off will work.
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#16 |
BAD BOW-Silverado XST
Use a bolt out once the cover is removed. If all fails, use a nut spiltter. Break if off if necessary. Ouch. Either way, I would put in a new stud.
