Old 03-21-2003, 03:26 PM   #1
highboy_04
highboy_04's Avatar
frame swap
i was wondering if anyone had any info on putting an s10 frame under a 47 chevy truck. the truck is a 1-1/2 ton right now but i would like to make it into somewhat of a street rod so i dont need the beefed up suspension. thanks
steve
highboy_04 is offline   Reply With Quote
Old 03-21-2003, 04:54 PM   #2
crazy longhorn
Fabricate till you "puke"
Us body source has an article on a glass 47-54 chevy body on an S 10 frame. I dont know if there is enough detail to help you with mounts /dimentions, ect....but it should be "doable". Here is the link..... http://www.usbody.com/ you will have to dig through the site, they also have a 40 Ford on a ranger chassis & it looks like these early trucks fit pretty well on the "pint sized" truck chassis. Good luck,crazyL
crazy longhorn is offline   Reply With Quote
Old 03-21-2003, 05:33 PM   #3
highboy_04
highboy_04's Avatar
where exactly do i find the section where it shows this?
Old 03-21-2003, 06:18 PM   #4
crazy longhorn
I think this is it..... http://www.usbody.com/thumb%20cover.htm
Old 03-21-2003, 06:23 PM   #5
crazy longhorn
it didnt open to the page.......click on trucks on the sidebar, then click on the truck you want(pic). Then click on install, & go down the list,& you will find the set of picks on the 47-54. crazyL
Old 03-21-2003, 10:22 PM   #6
Seon
Seon's Avatar
Try this: http://www.usbodysource.com/Install%2047%20chevy.htm
IMHO an S-10 frame is too light for 1 -1/2 ton truck.
Here's what I'm doing on my '57 Burb..
Mounting it on a '00 GMC chassis with Vortec running gear
Mounted the body today but still need to move the rear end 3" forward so it will fit properly.
Seon is offline   Reply With Quote
Old 03-22-2003, 02:50 AM   #7
highboy_04
highboy_04's Avatar
does the link work?
Old 03-22-2003, 02:52 AM   #8
highboy_04
highboy_04's Avatar
the rope is to hold the hood down so it doesnt blow off of there. its not bolted on because we just pulled the engine. let me know what ya think.....(bought it for 100 dollars)
Old 03-22-2003, 03:56 AM   #9
highboy_04
highboy_04's Avatar
thanks for all the help with the site for the swap.
'67 c10 350/th350
Old 03-22-2003, 10:53 AM   #10
Seon
Seon's Avatar
Highboy, you definitely do not want to us an S 10 for your truck. The tires will look too small in those fender wells, plus the front axle will be too narrow. Being that you don't have a bed on it and it's currently a dually, why not use a full size 1/2, 3/4 or even a 1 ton '70-'80's ChevyGMC? Here's a pic of my '56 GMC on a '77 Chevy dually chassis with a big block that I'll be using to do my "running to Home Depot" truck. Good luck.
Old 03-22-2003, 04:09 PM   #11
highboy_04
highboy_04's Avatar
but where do i find a chasis like that on the cheap? i actually measured the wheel wells they arent as big as they seem. they are actually the same size as my 3/4 ton 67 chevy. i want to build some kinda street rod outta it maybe. i was thinkin also on maybe setting it on a 4x4 chasis. my options are still wide open because i havent started anything yet.
i've been told that a 75 chevy frame wouldnt fit under there right. i have access to a 75 3/4 ton frame i was wanting to use. i was told it would take alot of repositioning of stuff.
'67 c10 350/th350
Old 03-22-2003, 04:11 PM   #12
highboy_04
highboy_04's Avatar
believe it or not those wheel well on my 67 in the pic are almost the exact same size as the ones on the 47.
Old 03-22-2003, 04:13 PM   #13
highboy_04
highboy_04's Avatar
this pic might show it better. little different angle
Old 03-22-2003, 07:38 PM   #14
Seon
Seon's Avatar
Quote "but where do i find a chasis like that on the cheap? "
I usually look in the local want ads, under "rebuildable" or "parting out".
Where there's a "will", there's a "way". Good luck.
BTW here's pics of my '56 Burb on the '00 GMC frame. I had to move the rear end 3" forward to center the front and rear tires in the wheel wheels. Just finished today.
Old 03-23-2003, 02:59 AM   #15
highboy_04
highboy_04's Avatar
what 4x4 chasis would fit under there?
