Carpe manana
![]() ![]() Join Date: Dec 2010
Aux fuel tanks: dealer installed? Worth keeping?
I'm mulling over what to do with a 72 K20 I recently picked up. The bed needs to be swapped out. The truck has dual bed mounted tanks and a three way selector on the driver side floor. Are these tanks typically dealer installed? Not sure if I should keep them for the resto I'm planning (i.e. install them on the other bed). The selector seems frozen but I'm reluctant to torque it too much. I'd appreciate your opinions. Thanks.
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Aux fuel tanks: dealer installed? Worth keeping?
Looks like you might have Travels Tanks (as I do), one of the more popular tanks back in the day. With poor fuel mileage, I like being able to carry plenty of fuel on board. They could be dealer-installed or from an RV supplier. As to keeping them (assuming they are in good condition), it depends on how you're planning to use your truck. I'm not convinced it's worth the effort to install them on an uncut bed, unless you think you would use the extra capacity.
Edit: Those valves can be hard to turn... maybe trickle some penetration fluid or WD-40 down the shaft and see if you can loosen it up. I think you can get new valves at NAPA or at RV stores. If you don't keep the tanks, you can probably sell them easily enough.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 03-24-2011 at 02:54 PM. |
![]() Join Date: Feb 2011
If it's a custom camper aux tanks were a factory option. And the tank selector on my truck is really hard to turn.
1971 C20 Longhorn Custom Camper |
Carpe manana
Thanks guys. It's a Cheyenne Super with no listed aux tank on the SPID so I assumed aftermarket or at best dealer installed. My preference (at least right now) is to take the truck back to stock and not keep the tanks on the truck.
Same tanks that my 72 SWB came with. The original owner, who I bought the truck from, told me they where dealer installed. I regret removing them when I got the truck in 2000, wish I still had them.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Feb 2008
As stated those are after market or dealer installed. The factory aux tank would be listed on the SPID with the code NL2 I believe. Valve on floor would be main and aux not main/R/L. Knob on left of dash to switch guage over to aux sender. Filler on factory tanks looks just like the cab tank and is located at the same height about 6 inches back on the bed. Since you were asking for opinions....
Get rid of it. Don't cut a good bed to mount those. Sell them to someone that wants them and if you want an aux tank mount it inside the frame where its safer. |
only reason to keep is if your plans for the future include frequent long distance traveling with a heavyily loaded truck
I kept mine and removed the tank in the cab. Extra storage space and I don't have to worry about riding next to a gas tank in a car accident.
SWB 4x4 Collector
![]() Join Date: Jun 2001
Saddle tanks are far more dangerous than the cab tank though. GM had major lawsuits from auto accidents in the late 70's because of gas tanks exploding in t bone accidents. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#10 | |
NBC got in trouble for rigging up the exploding saddle tanks. Besides if you only have one saddle on the driver's side, and somebody hits you that hard there in a t-bone situation, you have other problems than fuel leaking. The replacement valve thing just came up in a recent post. Scroll down to the bottom of: http://67-72chevytrucks.com/vboard/s...d.php?t=453477 I LOVE my saddle tank. I use it all the time. I have a buddy who ran a 66 4x4 for many years. The seat tank in that thing couldn't get us from the last fuel stop to the trail head where we went elk hunting and back. We had to carry a 6-gallon jerry can and hope nobody "borrowed" any gas while we were hunting.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
SWB 4x4 Collector
Well, I know a guy up by the Nebraska border whom we have ran into while searching towns for the next project. He now has a hook for an arm that came when his truck exploded in the late 70's from from of the saddle designed tanks getting hit in an accident. He was awarded several million dollars and has lots of muscle cars and trucks now. Trevor
#12 | |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Should you decide not to use the tanks, please put me on the list to buy them from you.
Al '69 GMC 2500 Custom Camper '69 Chevy C10 396 |
Carpe manana
alsriv2: will do.
Thanks again guys. |
#15 |
I've got a 72 C20 camper special with one of those tanks. Filler is between fender well and tire. I've been contemplating on whether to hook it back up or remove it. The valve doesn't say anything and there is no know or button to switch. I would like to get rid of the tank inside the cab. I got the extra tool box built into the bed also. (where can i find a lock for that?)
#16 |
Are those tanks steel or fiberglass? If they are glass I'd ditch them. The ethanol additive in most gasoline today will erode the resin in fiberglass tanks. The resin then deposits in the carb and every other component in the fuel system. It is causing all kinds of issues in the boating community. Plenty of info if you google it. Steel tanks on the other hand are not affected by ethanol.
#17 |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#18 |
Mine is steel.
#19 |
I mention this because mine are fiberglass. Just like these. (Not mine)
http://dallas.craigslist.org/dal/pts/2537110346.html |
#20 |
I got the same setup on both sides of my truck. I always though there were after market only, but I guess dealers too. I'm definitely getting rid of mine when time comes.
#21 | |
20' Daredevil (Ret)
Some dealers offered them...... as aftermarket, dealer-installed equipment. ![]()
#22 |
Carpe manana
I've since yanked the tanks and listed them on CL for sale. These are made of thick plate steel.
Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#23 |
![]() Join Date: Sep 2009
Pete, good move. I would hate to see you mess up a nice bed...lol
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
#24 |
The GMC I just got has them on each side under the bed. The fillers are in the wheelwells, so at least there are no holes in the bed sides.
I think I am going to remove them, as they hang down about an inch below the bed and I don't like the look. Besides, it would cost more to fill all 3 tanks than I paid for the truck!
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
#25 |
I need the dimensions of the side tanks. I was retarded and threw mine away thinking I didnt want them. And then If i did i could just buy new ones on line.
This was in 2009 when i did this. IM trying to have some built. But i need the measurements of the tanks. Sucks cuz I really need in order to move forward. |
