Old 03-24-2011, 04:33 PM   #1
Mechanic77
Brake hose question
I just bought a stainless braided brake hose kit for my truck and it has -3AN hose on it...my question is, is there going to be an issue with them being so small? I can honestly say I've never seen such small brake hoses, but I'm not sure whether or not it will affect the performance of the brakes. I realize it shouldn't have any affect on the pressure in the system, but I'm concerned that it might affect the volume/flow of fluid through the system maybe slowing the apply of the brakes....I don't know maybe someone smarter than me can chime in.
Thanks, Andy
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 03-24-2011, 10:49 PM   #2
lilpoindexter
lilpoindexter's Avatar
Re: Brake hose question
I got SS hoses from summit, I don't remember the brand, but they work fine. I think the rubber ones look bigger because the outer rubber covering is so much thicker.
lilpoindexter is offline   Reply With Quote
Old 03-25-2011, 11:07 AM   #3
Mechanic77
Yeah, I think they'll work fine....but I've seen the inside of rubber brake lines, and they are a lot bigger i.d. than these lines I picked up. I think I'm just going to try them and if they seem to be an issue, I'll just upgrade to -4AN hoses down the road
Old 03-25-2011, 12:49 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There is very, very little movement of fluid in your brake system. The pads and shoes are virtually right against the rotors and drums. It takes a tiny amount of fluid movement to apply them together. You're gonna be fine for sure.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-25-2011, 02:58 PM   #5
robnolimit
robnolimit's Avatar
Your #3 hoses are fine. The I.D. of the hose is the same as the I.D. of the hose.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
