Old 03-24-2011, 10:19 PM   #1
Leedogg
Let's play.....Name that differential!!!
Looks like a Dana 60 by the bolt pattern(using the LMC book)...am I right? If so- a 3.54 is as tall a gear they make?(in LMC anyway)
1989 R3500 dually.
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 03-24-2011, 10:22 PM   #2
Altec
Getcha Pull
Altec's Avatar
Re: Let's play.....Name that differential!!!
Dana 70.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-24-2011, 10:54 PM   #3
maynardtruckin
maynardtruckin's Avatar
If you look at the webbing that is cast as part of the center section it will tell you what it is. On any Dana they cast the size numbers in the webbing could be top, bottom, or ether side.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 03-24-2011, 10:56 PM   #4
Altec
Getcha Pull
Altec's Avatar
The 70 is easy to spot by the extra bit of meat below the bottom right area of the diff cover. The 60 doesn't have this.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 03-24-2011, 10:56 PM   #5
wyattglock
wyattglock's Avatar
Dana 70, check the numbers and it will tell you if it is an HD or a regular.
wyattglock is offline   Reply With Quote
Old 03-24-2011, 11:10 PM   #6
Leedogg
I planned to clean it tomorrow(oily- just on the chunck). Thanks for the info. Trying to figure out 1) what gear is in it(rediculously low) and 2)then what gear I want to run...hwy friendly(75-80mph) towing 5000#'s.
Old 03-25-2011, 12:09 AM   #7
pig rig
pig rig's Avatar
my money is its got 4.11 in it
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-25-2011, 08:17 AM   #8
Leedogg
The speedo it reads ~83 at 70mph. so it isn't the stock gear/rear end...or They messed up the speedo gear...not sure why it is that far off. 83 mph indicated is 3300-ish rpm.
Old 03-25-2011, 02:12 PM   #9
C-10 simplex
Or the rear tire sizes(diameter) may have been changed.
Verify if tire size is stock first to save headache.
C-10 simplex is offline   Reply With Quote
Old 03-25-2011, 02:29 PM   #10
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
if its a dually 1Ton its a Dana 70HD
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
