Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 03-27-2011, 12:42 AM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Question Electric Buffers/Polishers - Buyer's Guide
I'm at a point where I would like to locate an electric buffer for our ever growing fleet. This unit will need to work well with vehicles either having a clearcoat or not.
What rpm's should I stay away from?
What units do you have, and your experiences with them?
Pads - How long do they last? Which ones are better than the others?
Trying to cut down on the elbow grease it takes to keep everything deatailed during the year.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-27-2011, 12:51 AM   #2
hotrodhomi
hotrodhomi's Avatar
Re: Electric Buffers/Polishers - Selecting a versatile tool
Here's a good deal. just stay away from the edges. I would buy a pad for each polish you use.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-27-2011, 01:59 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I have looked at the Makita, and it appears to be a pretty good unit.
Anyone else?
-Nate
Old 03-28-2011, 01:51 PM   #4
colin_havens
colin_havens's Avatar
Anyone else?
Thats the unit I use, you just have to remember it is a PROFESSIONAL unit... meaning it WILL burn your paint if not used properly. I would avoid edges, and tape them up if possible to avoid burn through. It will however work much better and faster at removing swirls and minor scratches in your paint, and really polish it out so you can seal in the shine with some good glaze and wax. I have used some of the casual buffers that guarentee they "will not burn the paint", and for the adverage joe, they will be fine. I just cannot get the results I want from one of those, particualry on paint with lots of marring, swirls, and scratches. I highly reccomend the Makita buffer.
As far as pads, get one for each product you use. I have wool pads for cutting, and foam pads to use with my polishes. A decent buffing pad spur will help you get the wool pads clean, and you can wash the foam ones. Just replace as needed.
colin_havens is offline   Reply With Quote
Old 03-28-2011, 03:32 PM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Thats the exact one I have..I have buff tons of cars,Big trucks boats, you name it and it works like a charm...it is one of the lighter ones which you will be happy about when you get about 1/2 way down the first side and are trying to do the lower half ( sometimes I cheat and throw a jack under the middle to save on the back) the variable speed is smooth has an easy start stop so slinging stuff off the pan in minamial...antother thing you will like when it comes time to clean up the splatter..
these guys have given good advice on the pads (not very expencive) and you can wash them with gental soap and water just be sure to air dry and run a spur over them befoer you use them again...
on your compounds use less aggressive stuff than you need till you really get the hang of it...a few extra min of buffing is better than buffing the paint off....
just to get a feel for it when you get it buff the garage frig when your done drink a beer and look at what you have done ....if you see marks or have burned the edges take it as a lesson and start on side #2 ...it will give you a feel on how to move it or hold it so it feels comfortable
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-30-2011, 12:15 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Electric Buffers/Polishers - Buyer's Guide
I have been using buffers for several years. My first one was an El Cheapo from Walmart. I now have a Makita that Iuse for my 9" wool pads and I have a Porter Cable that I have the foam polishing pads on. I also have a small Porter Cable orbital that I use to put polish on with. I have found that the different brands have significant lower speeds than others. The Porter Cable that I have for the larger foam polishing pads runs a lot slower than the Makita buffer. Remember the larger pads at slower speeds burns less paint.
If you go with a buffer, I suggest getting the 3M quick-adapter that allows you to remove and install a pad with little effort. They are at most outlets that have automotive paint supplies.
Frank
Old 04-03-2011, 10:09 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I figured you would chime in Frank.
Anything to be concerned about with the RPMs of a buffer?
-Nate
Old 04-03-2011, 10:47 PM   #8
mbgmike
for the buck the Makita is the way to go. You can't be told how to use one you just have to do it. Not trying to piss anyone off but most things including buffing take skill. People can help with how toos but just buy the Makita and practice its a good unit. We abuse our equipment more than anyone should an want to. It costs us money.. not sayin its right. we have the makitas and the worker and tool both hit the ground at times They can take a lot of abuse and keep working. My money is on Makita. If you buy one and don't like it and the place you bought it from won't refund I will pay the cost and shipping to us. I can alway use another one
mbgmike is offline   Reply With Quote
Old 04-29-2011, 05:14 PM   #9
primrrd
primrrd's Avatar
i saw one for 69.00 bux at harbor freight... anyone used one of those.
primrrd is offline   Reply With Quote
Old 04-29-2011, 05:39 PM   #10
hotrodhomi
hotrodhomi's Avatar
I had 2. They last a combined time of 5 minutes before they either stopped spinning or the speed control was stuck at 100%. In my opinion, this is one of those tools that shouldn't be bought at HF.
'66 impala ht
Old 08-26-2011, 08:56 PM   #11
RUSHNBOBO
Yep, made the same mistake...it's just like any other kind of power tools
There's only two catagories:
--The ones that work..................."expensive"
--And the one's that don't work ...."cheap"
Got a Dewalt now ...love it, but the Makita and Milwakee are every bit as good IMHO
RUSHNBOBO is offline   Reply With Quote
Old 04-29-2011, 09:45 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I picked up the variable speed one for $34.99... so far so good.
Not the greatest but hey.
-Nate
Old 04-30-2011, 11:57 AM   #13
mbgmike
its been said for years "you get what you paid for" The makita is the best bang for the money. Plus I am eco friendly. a cheap tool ends up in the dumpster most times or a yard sale. plus when I die my son will have a quality tool to remember me I look at my dads tools. The only thing he bought that was quality was a set of craftmans tools in 1946 I still have and use them
Old 08-25-2011, 01:03 AM   #14
Handfull 54
Handfull 54's Avatar
I agree with the Makita guys. We used them at the Fire Station on all the trucks and diamond plate. I bought one for my vehicles. For a wool pad set the speed at 3. For polishing with a foam pad use speed 4. I got and old fender from a junk yard and practiced on it. Like you've been told tape the edges and keep the buffer flat. Let the machine do the work. If you see cloudy areas, then you need to be a little more agressive meaning more pressure. I use Meguires 105 for buffing and 205 for polishing. Using the 205 also eliminates the swirl marks. At least that's been my experience. Remember "Buy cheap, buy twice."
Handfull 54 is offline   Reply With Quote
Old 08-25-2011, 01:15 AM   #15
454stepside
i have a dewalt and love it turn the rpms down feather the trigger for corners and edges
454stepside is offline   Reply With Quote
Old 08-25-2011, 01:47 AM   #16
hotrodhomi
hotrodhomi's Avatar
mine slows way down too, but I prefer to tape off the corners and buff them by hand.
'66 impala ht
Old 08-25-2011, 03:48 PM   #17
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
pigspit
and a orbiting buffer
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-04-2011, 12:46 AM   #18
Fastfun
Fastfun's Avatar
I have a old Black and Decker Industrial variable speed that I use on new paint that has been color sanded and I use a Porter cable for older paint that needs to be repolished.
Fastfun is offline   Reply With Quote
Old 01-22-2012, 08:30 AM   #19
hotrod 80
mini truck racer
hotrod 80's Avatar
I have the older Black & decker also and it is a good buffer . I always look for them at the swap meets . I have the Harbor frieght also .
For polishing and wax application i have the 7424 porter cable . This thing makes maintaining way easier . I quarterly do a good clean and wax on the outside/DD cars . I am also 4 miles from the gulf so regular care is manditory . I have the velcro adapter and use the Lake county pads .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-04-2011, 06:25 AM   #20
2ndstoryslam
2ndstoryslam's Avatar
Flex 5 speed polisher. Weighs just under 5 lbs. Very compact, made in Germany. Spanks the Dewalt, Makita, Milwaukee, ect hard.
2ndstoryslam is offline   Reply With Quote
Old 01-23-2012, 03:05 AM   #21
2ndstoryslam
http://youtu.be/FfwbVzsphzs Here is a side by side of two of the best.
