ecm question
so i got my 87 the previous owner went to carb im trying to go back to tbi im getting all of my parts from 1991 suburban i dont know if i just plug wires to my ecm or use the one from burban also do i got to send it out to take sensors off and does this look like a ecm from a 87 im curios cuz it only has one plug the suburban has 2 thanks alot
Re: ecm question
anybody anyone
Re: ecm question
I would use all the wiring and the ECM from the burb. 1991 also has an electronic speedo. I'd use everything from the burb
![]() ![]() Last edited by joe231; 03-28-2011 at 07:38 PM. |
Re: ecm question
so if my truck has a 350 and a regular speedo do i have to convert it or can i keep it like that if not what all do i take from the burb do i take the gauge cluster i need help on this and do i take from the ECM to the fire wall and on to engine only or do i have to take the other plug too man im really going to need help on this also why would this truck have an older model moduel in it with the wires cut off
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: ecm question
That not a TBI ECM there. Looks like an ESC module from an earlier truck. In my 87, the computer is larger and has two large plugs.
Re: ecm question
My 87's ecm is larger also than what you have pictured with two plugs as well, I'd take everything out of the 'burban, the gauge cluster, ecm and the complete wiring harness if you can, unless you know for a fact that the carb conversion used the original TBI harness and left it completely intact, and even then I'd still grab the burb's harness on the off-chance something is missing. Your existing gauge cluster may work, mine is using one from an 85, so I have a "choke" light in place of "service engine" but it still functions the same. But again you might as well grab everything you can and have it rather than wish you did if something doesn't work.
87 GMC V15 in profile photo sold 2013 99 Chev Silverado 2500 5.3 reg cab long bed Last edited by sandorjoben; 03-28-2011 at 11:57 PM. |
Re: ecm question
so it is better to just take everything sinceim not sure and i know for a fact that only some of the wires from the tbi are there and by complete harness do you mean taking the complete harness for the engine only or you mean the whole harness also i know one of the plugs on the ecm is for the engine and the other is for interior if i only plug in the one for the engine will it affected the ecm any by only having one thing plugged in. thanks alot
Getting Old; Going Broke
Re: ecm question
As was mentioned, the box should have two plug ins on it and larger than what you have. One group of wires is engine bay and other is your interior. If you do not have the plug just dangling there for the interior loom, yes you should probably swap it out. The only thing that comes to mind is the VSS stuff, but there is probably more. The cab harness is fairly simple and straight forward as long as you have the dash somewhat apart.
Here is a photo of the extra ECM I have that would work on an 87-91.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Re: ecm question
how much do you want for the ecm also i had a question when installing tbi back on can you eliminate all sensors or is it better to have sensorscan this be done in a week end and from 1-10 how hard would ya rate this swap also any one in houston who done this before that can help
Re: ecm question
Don't know how well the truck'll run, if at all, if you start leaving sensors that should be there out when you bring the TBI back. If you have the help of at least one other person you can do it on a weeknd without too much difficulty. If you think you might end up forgetting what gets plugged or routed where wire/connector-wise snap photos while you're removing the gear you're taking from that suburban you're taking parts from. That way you'll remember what goes where.
87 GMC V15 in profile photo sold 2013 99 Chev Silverado 2500 5.3 reg cab long bed |
