Old 03-28-2011, 11:42 PM   #1
Blue Heeler
Blue Heeler's Avatar
anyone have pic's on a 5 inch drop?
I lowered the front 3 inches front and 4 rear i wanna go lower in the front to 5 inches and 6 rear I dont want to bag so if anyone has pic's on this i would really like to see them!! anyways thanks for the help.
Blue Heeler is offline   Reply With Quote
Old 03-28-2011, 11:55 PM   #2
Lolyin58
Lolyin58's Avatar
Re: anyone have pic's on a 5 inch drop?
I will have some pictures posted tomorrow night of my truck. It is 5 in the front and six in the rear. It will give you an idea though. It has 18's and 20's.
Lolyin58 is offline   Reply With Quote
Old 03-29-2011, 06:52 AM   #3
1966JSM
heres my 66 c10 with a 4 1/2 and 5 1/2 drop on 22's
1966JSM is offline   Reply With Quote
Old 03-29-2011, 08:45 AM   #4
63 & 64 Bowties
and a few others
You may want to reconsider. That's just too low for a static drop with stock A-arms...
http://67-72chevytrucks.com/vboard/s...d.php?t=442767
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
Last edited by 63 & 64 Bowties; 03-29-2011 at 06:09 PM. Reason: felt like havin a peanut butter & jelly sandwich
63 & 64 Bowties is offline   Reply With Quote
Old 03-29-2011, 09:12 AM   #5
lakeroadster
Originally Posted by 63 & 64 Bowties View Post
You may want to reconsider. That's just too low for a static drop...
Now that's a real eye opener.
Guys running deep "cupped" lower a-arms and rear lowering blocks should take note. The term "Scrub Line" comes to mind.
lakeroadster is offline   Reply With Quote
Old 03-29-2011, 06:07 PM   #6
63 & 64 Bowties
and a few others
Yup, any static drop lower than 4" up front with stock A-arms and you're asking for trouble. To quote Fatman Fabrications in Charlotte, NC who worked on the 55 in the above mentioned article:
This is also a problem on '63-'87 Chevy Pickups that have been lowered more than 4" The lower control arms get REALLY close to the ground with any more drop. Two guys here in town have gotten hooked the same way as the subject '55. There are ways to lower the truck more, but they are going to involve more bucks, as the entire suspension will get replaced, but gaining a couple inches ground clearance, and a slightly narrower track for tire clearance.
Old 03-29-2011, 08:54 AM   #7
paul63c10
hey man. got any pics on here of your 3/5 drop?
paul63c10 is offline   Reply With Quote
Old 03-29-2011, 10:05 AM   #8
Blue Heeler
I do have some pic's i've tried many times to load them and cant figure out
how to do this. if someone can give me a hand i'll post some. thanks
Old 03-29-2011, 10:36 AM   #9
63 & 64 Bowties
and a few others
http://67-72chevytrucks.com/vboard/s...d.php?t=209103
Old 03-29-2011, 09:04 AM   #10
admiral grey bush
admiral grey bush's Avatar
3" springs up front with a coil cut off and 5" springs with 2" blocks in rear.. No scrubbing problems... Except tailpipes..
admiral grey bush is offline   Reply With Quote
Old 03-29-2011, 05:38 PM   #11
Wolfy
how does the front end ride? did you cut your stops?
Wolfy is offline   Reply With Quote
Old 03-29-2011, 02:40 PM   #12
oldblu65
oldblu65's Avatar
http://www.earlyclassic.com/tech.asp...=stance+photos
" The lesson is in the struggle , not in the victory "
oldblu65 is offline   Reply With Quote
Old 03-29-2011, 06:14 PM   #13
Malibob
Malibob's Avatar
I can definately vouch for that. Leaving downtown Pittsburgh one day I was cruising real low and all of the sudden heard WHAM and came to a complete stop. Turns out there was a steel plate in the middle of the road that I decided needed moved about 3" or 4" infront of me. It hit the control arm stopping me in my tracks and moving the plate. Luckily I did not damage the frame or crossmember (bent the shlt out of the control arm though) but to resolve the issue I did get a chopped crossmember which will bring the center of the truck (control arms and all) up 1 1/2". This should resolve the issue and give me another 1.5" drop when I am all aired out.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 03-29-2011, 10:42 PM   #14
Original Truckdude
Original Truckdude's Avatar
5" front/6" rear drop:
Currently blown apart for paint and a full resto. Boxing the CPP C-notch right now. Early Classic 2" drop spindles, 3" drop springs and a CPP sway bar up front. Early classic 6" drop springs along with an EC adj. panhard bar and shock relo kit, Hellwig sway bar out back. KYB drop shocks all around. Later model PS, PB and front discs. Auburn posi. Poly cab mounts. Handles great.
The dude abides.
Original Truckdude is offline   Reply With Quote
Old 04-10-2011, 10:45 AM   #15
Blue Heeler
Do you have any frontend pics lowered? I have the cpp 3" springs up front and gonna put 2 inch droped spindles up front just wanna know what is the clearance from ground to frame. Thanks for you help.
Old 04-10-2011, 10:55 AM   #16
protrash64
Resistance is Futile
protrash64's Avatar
Hey Blue, it's going to vary depending on your tire size. Originals truck doesn't look like 5'' to me, but the front tire could be smaller than it looks. I'm running 275/40/18's on my shorty and it will barely clear a 2x4 like vin showed. Tire is roughly 26.5'' in diameter. I used 3'' springs and 2.5'' spindles.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-10-2011, 11:03 AM   #17
Blue Heeler
I'm running 275/60/15 rear 245/60/15 up front, i'm going to take some pictures
today and post them up. I figured out how to post so maybe some pic's will give better ideal of where i'm at. thanks
Old 04-10-2011, 04:05 PM   #18
Blue Heeler
Here's what i shot today.
Old 03-30-2011, 02:33 AM   #19
Blue Heeler
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 03-30-2011, 06:11 AM   #20
thunder71
thunder71's Avatar
here's mine ,5" springs in rear...3" springs in front with 2 1/2" drop spindles...
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
Old 03-30-2011, 07:09 AM   #21
Lolyin58
Lolyin58's Avatar
Here's mine with 5 in the front and 6 in the rear!
Old 03-30-2011, 09:29 AM   #22
admiral grey bush
It rides just fine.. I cut the bumpstop mounts off.
Old 03-30-2011, 10:50 AM   #23
Blue Heeler
What size tires you running on that bad boy? looks good.
Old 03-30-2011, 11:06 AM   #24
admiral grey bush
[QUOTE=Blue Heeler;4588418]What size tires you running on that bad boy? looks good. Ive been running it this way for about 4yrs
Old 03-30-2011, 11:04 AM   #25
admiral grey bush
Thank you.. 255/60/15 rear with 8" wheels and 235/60/15 up front with 6" stock wheels..
