Old 04-01-2011, 12:43 PM   #1
fattyarbuckle
Question need a 1bbl carb for 250 I6
Where is the best place to find a stock replacement carb for a 250 I6, auto choke?
I think (know) we need a rebuild but the phillips head screws that hold the two halfs together must have locktite on them because they are not budging!
I'm afraid to put heat on them until we have a scource for another in case this one is damaged...any suggestions or help would be appreciated.
fattyarbuckle is offline   Reply With Quote
Old 04-01-2011, 12:51 PM   #2
BadaSs_Cal
BadaSs_Cal's Avatar
Re: need a 1bbl carb for 250 I6
I got a real nice refurb one from ebay for $100.. or you can pay a little more and go with langdons 2 bbl weber, if their in stock.. I might go that way next.
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 04-01-2011, 12:56 PM   #3
fattyarbuckle
You got a link for the langdons?
Old 04-01-2011, 01:27 PM   #4
BadaSs_Cal
BadaSs_Cal's Avatar
http://stoveboltengineco.com/index.p...roduct=1681888
He also has the adapter and the linkage for sale there... But maybe you can come up with something?? Try calling them up and see what they say.. I always hear they are very helpful.. Good luck!!!
Next a 50-53!
MY BUILD THREAD
Old 04-01-2011, 02:34 PM   #5
68 IRON
68 IRON's Avatar
Mr Arbuckle, heres a trick we use at work for stuck panels. Put a small dab of valve grinding compound on the tip of your screw driver and tap it into the philips head screw (just tap it lightly with a small hammer or another tool thats handy). Keeping downward pressure and not pulling driver off the head of the screw loosen it. The compound gives additional bite to keep the driver from spinning out and rounding the screw head. Just remeber to keep the pressure on the head of the screw after tapping the driver into the screw.
68 IRON is offline   Reply With Quote
Old 04-01-2011, 02:53 PM   #6
Shyguy
Junior Member
Shyguy's Avatar
An impact screw driver may also work. I use to use one a lot when I rode dirt bikes.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-01-2011, 02:57 PM   #7
fattyarbuckle
We've already tried and impact driver and hit it hard enough that it should have broken so we stopped...LOL
I thought about cutting a straight slot in the head to get a flat blade on it but still think we should have something here in case it's trashed...
thanks everyone
Old 04-01-2011, 03:01 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
Lowe's and Sears both carry screw extractors, these may work.
Old 04-01-2011, 03:27 PM   #9
BadaSs_Cal
BadaSs_Cal's Avatar
Can you just grind the little heads off then once you have the halves apart get a vice grip on them to twist off??? Thats what I would try...maybe with a dremel with a grinding disk.
Next a 50-53!
MY BUILD THREAD
Old 04-01-2011, 04:08 PM   #10
fattyarbuckle
yep, that is our last option...it will come apart, it's just a question if we destroy it or not...LOL
Old 04-01-2011, 04:15 PM   #11
Wrenchbender Ret
Ive got some parts carbs if you need any parts for it. There were several different typs of chokes used on these through the years & the manifolds have to match. The best one is to find a carb with elactric choke. They work slick & will work on any manifold.
georgec2434@yahoo.com
Wrenchbender Ret is offline   Reply With Quote
Old 04-01-2011, 06:54 PM   #12
What year is your ruck. I now the '72 Monojets are different.
