Old 04-02-2011, 01:49 AM   #1
Btc10
Original radio installation speaker / hook up problem
I got my original 1970 c10 GM AM radio reconditioned the other day and I hooked it up with the speaker and antenna with no problem started working just fine so then I notice I forgot to put the mounting bracket on the back of the radio and bolt it up so I took out my radio and put the bracket on with the screws and hooked everything back up and nothing..... I have power to the radio because the light bulb is on in the radio so I know its getting power but, no sound at all. Can somebody please help me fix this problem????
Btc10 is offline   Reply With Quote
Old 04-02-2011, 02:10 AM   #2
red71c10
The Red Menace
red71c10's Avatar
Re: Original radio installation speaker / hook up problem
Turn up the volume? Seriously though, all I can say is double check everything. Make sure the plugs in the back of the radio are all clean and making good contact. Make sure neither of the wires attached to the speaker have broken and come loose. Check where things ground out too, make sure those areas are clean too! Are you using an OEM or aftermarket speaker?
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 04-02-2011, 02:18 AM   #3
Btc10
I'm using a aftermarket speaker from classic truck parts of america. It kind of looks like an original one.
Old 04-02-2011, 07:21 AM   #4
Luvlegs
Luvlegs's Avatar
antena plugged in?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 04-02-2011, 09:23 AM   #5
stich626
did you pull on the wires and unplug the wires(or one) from the speaker?
if not.. I'd call the shop that fixed it..
if your sure everything is hooked up..
stich626 is offline   Reply With Quote
Old 04-02-2011, 06:46 PM   #6
Btc10
I got it working. I cleaned the contacts and I didn't hook the speakers up right. Oh well its working now. Thank you all for the information and your time.
