04-02-2011, 06:59 PM | #1 |
Young gun
gas tank?
so my original plan was to relocate the fuel tank to the frame rails but my projects budget is pretty tight now and im wondering if its really worth it to relocate or stay stock, so do the pros really out weigh the cons?
67 SWB Custom "JANE" http://67-72chevytrucks.com/vboard/s...d.php?t=554024 Northwest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ Cameron sparks |
04-02-2011, 08:03 PM | #2 |
its all about the +6 inches
Re: gas tank?
I'd leave it alone if it doesn't leak. Assuming it doesn't leak, it's safer in the cab anyways. The location most people move it to is one of the worst places to put it.
04-03-2011, 01:50 AM | #3 |
Re: gas tank?
Safer in the cab? I think that is open for debate, however, if the tank does rupture mounted in the back of the truck you don't take a bath in gas as you would with the tank in the cab. Weight distubution is better with the tank in the back.
04-03-2011, 11:54 AM | #4 |
Re: gas tank?
They worked for years this way and still do. maybe we are creating a bunch of C10 pintos by putting them in the back
04-03-2011, 12:21 PM | #5 |
Re: gas tank?
You might be right but I'd still like to move mine from behind the seat for the storage space but I wont the spare tire left alone, I'm thinking about building a tank that will fit under the cab or under the front of the bed if thats possible maybe two tanks on either side of the drive shaft.
04-03-2011, 02:54 AM | #6 |
Re: gas tank?
Oh no, not this debate. Well, without getting too far into this classic..Ill just say I put a racing cell in my custom back-half. My pros or reasoning for it was so I could shave the filler hole and the leg room is really nice. The con I guess would be the cost but there are cheaper ones out there or you can make your own if you trust your welds. I have had 3 other 67-72's that were closer to stock and was just fine with the tank behind my seat.
04-03-2011, 10:14 AM | #7 |
Active Member
Re: gas tank?
As long as the tank is not leaking I don't mine being behind the seat.
04-03-2011, 12:46 PM | #8 |
Re: gas tank?
how can you get leg room from ditching the tank? The seat hits the cab before it gets to the tank, and if you were to modify to move the sseat further back, then you'll have to sit the seat too far verticle to be comfortable.
9 times out of ten, if the in cab tank gets ruptured from an accident, then you have bigger things to worry about, like a car hitting your hip. If you get rearended, usually the car hitting you will go under your truck and the tank will get sliced open dumping fuel all over the hot engine of the car parked under your rear bumper. In this day and age, ambulance chacers would go after you BIG TIME if you catch there client on fire. In bed fuel cell should be very safe, and a tank or two inside the frame, forward of the rear end is probably the safest place. |
04-03-2011, 01:00 PM | #9 | |
Re: gas tank?
04-03-2011, 01:13 PM | #10 |
Re: gas tank?
It depends on what seats you are running. No running a stock bench wont do you much good because they do hit the cab wall. But with my seats I mounted the tracks 1 3/4 inches back which dont sound like much but thats the first thing any 67-72 owner says when they sit in the truck. and they are at a pretty normal angle, maybe a tad straight but thats how i have my seats in my daily so i dont notice. Plus I have alittle bit of storage space, Not much but certainly more than I had before. i keep spare air line, valves you name it for that inevitable 2 am air ride failure. Then again shes never been on the road so..
04-03-2011, 02:28 PM | #11 |
Re: gas tank?
IMO I like mine in the cab, thats where they were in the first place and theyve been in there for 40+ years and i grew up ridding in a old 71 that was rusted out to heck but i survived. I remember the floors were so gone if we wanted to throw or pour something out wed just pour it out the rust hole. If mine rotted away i would probably put it in the bed not under it because with all these "low ridding rice rockets" that like to tail you now a days will end up under your truck if you were needing to stop. If your worried about a safety these old trucks really arent for you but as long as you dont drive it like a newer car you shouldnt have to be too concerned IMO.
1969 Chevy c20(Miss Hackjob) |
04-03-2011, 02:58 PM | #12 |
Re: gas tank?
Nothing like no radio, the sound of the engine, and that sloshing gas in the tank to really feel the classic truck experience. I'll never move mine!
04-03-2011, 03:21 PM | #13 |
Re: gas tank?
Haha! I have the same feelings. Going up onto my driveway the sloshing sound of the gas tank is music to my ears.
Thanks, Emil 1972 Chevy C20 |
04-03-2011, 03:22 PM | #14 |
Re: gas tank?
And dont forget the smell of gas that after a while puts a smile on your face
04-03-2011, 03:42 PM | #15 |
Young gun
Re: gas tank?
thanks everyone ill stick with it in the cab
