04-02-2011, 11:20 PM | #1 |
Sound Deadner
So last night, I had a little extra time so I figured I's start taking my doors apart and order some weatherstripping, etc. After pulling the upper door panel, it looks like the previous owner glued sheets of 1/2 inch styrofoam to the inside of the doors!
not sure what that's all about but it took me a few hours of carving the glue off with a razor blade.... No rust currently exists inside the door and I found some rubberized undercoating/silencer at PepBoys. So, my plan was to spray some extend rust inhibitor stuff inside, let it dry then a light coat of this sound deadner and put the doors back together. Anything wrong with my plan? I've heard mixed reviews on using undercoat and stuff so looking for advice/opinions. Thanks! |
04-02-2011, 11:32 PM | #2 | |
Re: Sound Deadner
04-03-2011, 12:00 AM | #3 |
Re: Sound Deadner
That undercoating/silencer at PepBoys 2 cans for $7.00 works great
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! |
04-03-2011, 08:11 AM | #4 |
Re: Sound Deadner
2 votes for FAT MAT
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
04-03-2011, 11:54 AM | #5 |
Re: Sound Deadner
I used a product called Peal and Seal. It's a roofing product available at Lowes for $12 a roll. Here's a few pics of it installed. The last one is of the area behind gas tank. I used trunk carpet material and installed with 3M adhesive. Mostly covered with gas tank now, but looks great IMO. Oh, forgot to add, the rolls are 6" x 25'.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 Last edited by magicoolbus; 04-03-2011 at 11:57 AM. Reason: added more info |
04-03-2011, 02:17 PM | #6 | |
Re: Sound Deadner
04-03-2011, 04:09 PM | #7 | |
Re: Sound Deadner
Byron |
04-03-2011, 05:21 PM | #8 | |
Re: Sound Deadner
I'd like to steal your idea if you give me the details...promise to give you full credit! |
04-03-2011, 06:18 PM | #9 |
Re: Sound Deadner
RE: Peel and Seal. Don't really know if it's as good or better than Dynamat, I do know that it's tons cheaper. I have seen some detractors from using roofing materials in cars/trucks, they say that when heated up, it smells like asphalt. Don't think I could have a more harsher environment than Mesa AZ. I have had interior temps over 140 from sitting in the sun, no asphalt smells. It goes on very well, adhesive is super strong, gonna a be a real PITA to remove if I ever have to. Just to ensure superior rust protecton underneath, I POR15'd the entire cab interior where I put the Peel & Seal. I also sealed all the seams with aluminum tape.
To avoid hijacking this thread, I will start a new one with more of my finished interior.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 |
04-03-2011, 05:18 PM | #10 |
Re: Sound Deadner
FATMAT is exactly like dynamat. Except alot cheaper. you can get like 50 square feet for like 69 bux
04-03-2011, 09:01 PM | #11 |
Re: Sound Deadner
I use e-dead from eBay. It weighs much less and still deadens vibrations. The peel and seal is similar but neither is "as good as" dynamat. Dynamats just not worth the money personally. Go for the fatmat, you'll be satisfied.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
04-03-2011, 09:15 PM | #12 |
Cruzin
Re: Sound Deadner
this guy used the lowe's stuff as well,http://67-72chevytrucks.com/vboard/s....php?p=4512620 I have a roll i'm thinking of useing in my doors myself
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
04-03-2011, 09:28 PM | #13 |
Re: Sound Deadner
here are a few reviews from the lowes website. Both are about use in automobiles.
http://www.lowes.com/pd_154017-81326...l%2Band%2Bseal Here is what the manufacture says it will do http://www.paceproducts.com/peel-n-seal.htm good info...... I might have to go this route. thanks for the info
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan Last edited by rhodog77; 04-03-2011 at 09:35 PM. |
04-03-2011, 10:17 PM | #14 |
Re: Sound Deadner
I have Peel and Seal in both of my AD trucks,
works great
04-04-2011, 04:33 PM | #15 |
Re: Sound Deadner
I tried to find the 6" rolls up od Peel & Seal here in Canada but no one carried it, finally found it at a roofing company in the 36" x 33.5' roll.
I plan on putting in 2 layers of the stuff! Anyone try to layer it, will it stick to the backing? Last edited by Atomsplitter; 04-04-2011 at 04:34 PM. |
04-04-2011, 04:58 PM | #16 |
Re: Sound Deadner
magicoolbus,
did you use this stuff up in the headliner? think it would stick hanging upside down? |
04-04-2011, 04:58 PM | #17 |
Re: Sound Deadner
While he does carry products, this isnt a site that is out to sell things.. he actually tells you what to look for so you can find it cheaper locally... that said, read what this guy has to say: www.sounddeadenershowdown.com
If you follow his advice, not only will you save money on sound dampening material, but your truck will be quieter then a brand new luxury car. |
04-05-2011, 08:04 PM | #18 | |
Re: Sound Deadner
It is worth the read regardless. Posted via Mobile Device
Project Bad Karma |
04-04-2011, 05:03 PM | #19 |
Re: Sound Deadner
anybody tried squirting that expanding foam stuff into the space between thew inner and outer roof panels. maybe a good idea? or not?
04-04-2011, 09:40 PM | #20 |
Yellow truck club
Re: Sound Deadner
Some of that foam is a high expansion item and I've seen vans with the side bumped out from it.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
04-04-2011, 11:53 PM | #21 |
Re: Sound Deadner
It sticks like the dickens. I didn't layer it, but i'm sure it will work. Living in AZ i didn't have any issues with the shop temperature during install like I read others had in colder climates. I didn't put it above the headliner yet, currently putting in on the roof of my burb. Prepping it for a rear a/c install. This is a my start of that insulation job. I used some jobber size peal and seal I got from a local roofing contractor wholesaler. It's wider, but still 25' long. I didn't like it as much as the stuff I got at Lowes, it had more of a texture to it, but since it's gonna be covered I didn't care.
04-05-2011, 12:20 AM | #22 |
Re: Sound Deadner
This peel and stick sounds pretty good, does it work well to stop heat transfer as well or just sound?
1949 Chevy/ S-10 1966 Chevelle Malibu 2002 Chevy Z-71 |
04-05-2011, 01:08 AM | #23 |
Re: Sound Deadner
Brian, that over expansion is what I'm worried about. Think I'll check into the stuff, see if there's different types available.
04-05-2011, 01:33 AM | #24 |
Re: Sound Deadner
I did the P/S on my 53 and my 07 Tacoma. I noticed a HUGE difference with the Tacoma. The doors sound solid when you close them. Cab is also a lot quieter now. I plan on using it again on my 59.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
04-05-2011, 06:55 PM | #25 |
Re: Sound Deadner
lowes great stuff ? blue can low expansion foam, not supposed to bow window panes or anything.
rattle trap, is like fat mat, only a lot thicker, for a little more cost. anyone use it? Last edited by skip99; 04-05-2011 at 07:18 PM. |
