Old 04-03-2011, 02:35 AM   #1
SHORTDOG99
Exclamation Looking for answers
Hey guys, I picked up a 5 lug 12 bolt Chevy rear end with posi and the guy i got it from said it was out of a 67 C10.
But if it was, shouldn't it have been a 6 lug?
I started to clean it up and came across some numbers, maybe you guys can help me out with this. Standing in place of the driveshaft looking at the rear end just to the right of the pumpkin (drivers side) i found a GM63 and in the same place but on the left side (passenger side) i found the numbers 3896838 N
and then further left on the actual axle tube i found some numbers stamped into the tube that read RHB (which looks to be stamped over an "RF") then W356 2 E (which would be the number to go by? the "RHB" or the "RF"?) so can anybody decode this and tell me what year / model this rear is out of so i know what brake parts to look for? I am pretty sure it has either 3:07 or 3:08 gears. Thanks for your help guys!
SHORTDOG99 is offline   Reply With Quote
Old 04-03-2011, 10:11 AM   #2
skip99
skip99's Avatar
Re: Looking for answers
it's not all of them but might help..
http://www.novaresource.org/axle.htm#Castings
skip99 is offline   Reply With Quote
Old 04-03-2011, 10:34 AM   #3
Rude Dude
Rude Dude's Avatar
Here is width on rear axles
http://carnut.com/specs/frear.html
Rude Dude is offline   Reply With Quote
Old 04-03-2011, 01:31 PM   #4
sandnuriz
sandnuriz's Avatar
Great info guys but it seem like I can never find my numbers this is what I have found KDU W305 1 on the axle tube passenger side and on the diff 3896839 N
great I know its a 1975 12 Bolt 6 lug with 3.07,told from PO Just was hoping for posi oh well
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 04-03-2011, 04:19 PM   #5
craig32
Shortdog, my truck has a 3896839 axle in it, only it is a 6 lug 12 bolt truck differential. Mine is from a 78. I think it is also a 3.08, non posi. How big is the 'pumpkin' on yours? Mine is huge. I guess that wasn't much help!
craig32 is offline   Reply With Quote
Old 04-03-2011, 10:19 PM   #6
SHORTDOG99
Does anybody else know of any other websites that give "decoding" info on GM rear axles? I still can't find any info on the numbers that are on the axle!
Old 04-04-2011, 06:25 AM   #7
55dude
55dude's Avatar
if it's 5-lug it's not pre 70', probably a 71'-87' rearend
55dude is offline   Reply With Quote
Old 04-04-2011, 11:28 AM   #8
SHORTDOG99
That's exactly what i thought. So far i am coming to the conclusion that it is a 71-72 rear but i am not positive! I want to know so i know what year wheel cylinders and brake parts to buy.
Old 04-04-2011, 11:47 AM   #9
jw4580
jw4580's Avatar
My 72 1/2 ton had the 3896838 rear end in it, 5 lug non posi. My dad's 75 1/2 ton also had the same rear end.. Not sure if that helps at all.
jw4580 is offline   Reply With Quote
