Old 04-04-2011, 12:34 PM   #1
Gene
Gene's Avatar
How to test power brake booster
I'm slowly trying to put my truck back together, and I have bled the brakes and bench bled the master cylinder, and it feels like I have a good firm pedal but I have to put alot of pressure on them to stop? I dont hear any noise coming from the booster like some i've heard. The brakes were working fine before I took the truck apart? I checked vaccum at the manifold and i'm reading 15 in. Hg.
Gene is offline   Reply With Quote
Old 04-04-2011, 01:05 PM   #2
Gene
Gene's Avatar
Re: How to test power brake booster
Forgot to say, i'm using a stock 71 booster and master cyl. to power 91 brakes on 91 differentials, I dont think this has anything to do with the problems but you never know?
Old 04-04-2011, 01:09 PM   #3
treveiger
treveiger's Avatar
Interested also
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 04-04-2011, 01:31 PM   #4
stich626
hand held vac pump. it should hold vac.
stich626 is offline   Reply With Quote
Old 04-04-2011, 01:41 PM   #5
Gene
Gene's Avatar
I've got a handheld vaccum brake bleeder, that should work right? Well, I hooked it up and it wont hold any vaccum at all. So whats my next step? Is there any repairing my old one or just replace it?
Old 04-04-2011, 01:56 PM   #6
Gene
Gene's Avatar
I also checked another later model booster that I had laying around, it wont hold vaccum either? What are the chances that I have 2 bad boosters?
Old 04-04-2011, 02:10 PM   #7
stich626
iirc you have to push on the pedal then pump.the vac pump..
Old 04-04-2011, 02:17 PM   #8
Gene
Gene's Avatar
Ok, hooked up the pump and pushed on the pedal and still not holding vaccum at all.
Old 04-04-2011, 08:38 PM   #9
hayhauler71
hayhauler71's Avatar
The booster should hold vacuum with out pushing the brake pedal. Make sure your vac pump has a good seal and it will take more than a few pumps to pull vacuum in a booster. Also make sure your vac pump will hold vacuum.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-04-2011, 09:09 PM   #10
Gene
Gene's Avatar
I know the pump is good, I used it to bleed my brakes and it held good vaccum during the process. So, exactly what goes bad in the booster.
Old 04-04-2011, 09:42 PM   #11
hayhauler71
The rubber diaphragm inside.
Fuzzy
Old 04-04-2011, 11:38 PM   #12
ls1nova71
ls1nova71's Avatar
With the engine off, pump the brake pedal to remove all vacuum, the pedal should be hard. Then push the pedal down and start the engine, if the pedal goes down, it's working, if it doesn't, it's bad.
ls1nova71 is offline   Reply With Quote
