Old 04-06-2011, 03:12 PM   #1
npc1
npc1's Avatar
67 chevy rear end ?
Ok like I have said before Im really new to the 67-72 chevy trucks. I have a 67 chevy swb everything is stock as far as suspension goes (still has 6 lug drums all the way around) Im going to install a drop member from Porterbuilt so Im going to change the front to 5 lug but my problem is the rear axle I can buy the gears and the posi for around 600 and I can buy new axles and drums for about 500 which is not bad I guess but Im thinking Id be better off finding a 73-87 rearend that already has the gears and is already 5 lug and then I will just add the posi to it. So basically I need to know if this is possible (in other words will the newer rearend fit) and if not what do I need to do? If someone can point me in the right direction or show me where to look I would greatly appriciate it. Thanks again.
npc1 is offline   Reply With Quote
Old 04-06-2011, 05:28 PM   #2
nds1968
nds1968's Avatar
Re: 67 chevy rear end ?
Coil or leaf spring rearend, what do you have now? 71-72 rearends are 5 bolt. 73 and newer rearends have leaf springs. If you have a coil spring setup you will have to do some cutting and welding to make the 73+ rearend work. But CPP sells a kit you can use to make a leaf spring setup work with coils (cutting the old brackets off and welding new ones on. I believe 1970 and newer rearends are a bit wider than what you have now.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 04-06-2011, 05:35 PM   #3
nds1968
nds1968's Avatar
Here are a few kits from CPP that make a rearend work with a coil spring setup.
http://www.classicperform.com/Store/...ck/6072RCK.htm
http://www.classicperform.com/Store/...ck/6072RAS.htm
http://www.classicperform.com/Store/...k/6072DRCK.htm
Nate
Old 04-07-2011, 12:23 PM   #4
npc1
npc1's Avatar
Its a coil spring set up. I think I found what Im looking for some guy on Craigslist has a 72 rearend out of a chevy that is 5 lug and has 3.73 gears. As for cutting and welding Its not that big of a problem for me being that I have both in my shop. I was really just tring to get from spending the extra money on making the rearend I want.
