Fuel pump still leaking
Well I replaced my leaky fuel pump but now where the hard line goes into the pump is still leaking. It tight but still leaks. Has anyone dealt with this problem? Getting frustrated and very smelly. HELP
Grandpa in the rustmobile...
Re: Fuel pump still leaking
Yeah, I went thru this, I cant remember how I got it to seal up. Is it a pre flared joint or did you do it?..
I just kept loosening, tightening and finally got it to seal, I even tried a new fuel pump and a new hard line!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
It is pre-flared and its a new fuel pump and a new fitting. I'll try looseining and tightening again just sucks with that gas running down my arm.
rudy67chevy
vettevet It leaked real bad with the hard line so I cut it and ran a rubber hose half way down to the fuel pump with a new 90 degree fitting, but still leaks but not as bad.
rudy thanks for warning. |
runnin the rubber line like that is a great way to burn the truck to the ground
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Have you checked the line itself for a crack in the flare. I take it that it's on the carb side.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Eat, Sleep, Drive a Chevy
When you want it done right.....(you know the rest) glad you got it!
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
Cruzin
yea the looseing tighting thing worked for me after a few times
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Glad it worked out for you.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
toys'r'us
On my friends truck we had the same problem comeing out the fuel pressure regulator. We tried teflon pipe dope and teflon tape. Still leaked. Then our millwright friend put on on a layer of dope, then tape, then more dope. The thing sealed!!!
71 jimmy bone stock 350 sm465 33x12.5 rallies 79 caprice landau full load crate350 th350 lowered 20"wires 00 f150 reg cab sb 4x4 5.4L |
wont leak till all the crap disolves
![]() andyboy glad you got if fixed no more leak and now you have cool tools that will always be there for you to do it right
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-09-2011 at 08:00 AM. |
