Old 04-08-2011, 01:44 AM   #1
bikes&bowties
bikes&bowties's Avatar
Brake fitting sizes
On the flex brake line that comes down to the rear axle and has two female spots. What's the size on that -3an? Also on a mid 70's front caliper. Standard or metric banjo bolt?
bikes&bowties is offline   Reply With Quote
Old 04-08-2011, 01:55 AM   #2
ray_mcavoy
Re: Brake fitting sizes
Hi bikes&bowties,
The two female ports on the rear axle flex line are SAE 45 deg inverted flare (not AN flare which is 37 deg). They accept 3/16" diameter double flared brake line with 3/8"-24 threaded nuts.
GM changed from standard to metric banjo bolts on the calipers sometime in the late 70's (around 78 I think). So mid 70's calipers should be standard ... 7/16"-20 thread if I remember correctly.
ray_mcavoy is offline   Reply With Quote
Old 04-09-2011, 12:47 AM   #3
bikes&bowties
Awesome. Thanks a million
