Old 04-10-2011, 06:30 PM   #1
HSkinner
I've got power coming out of the negative side of my battery???
K' Just finishing up my truck and I was dialing in the carb when I went to crank it over and lost all power to everything. I checked for the obvious stuff and got the tester out and discovered that the entire block, frame etc. had power going through it. The positive side had nothing... I freaked and unhooked the battery and started checking for a grounded wire somewhere and found nothing. I never saw a spark of any kind. no burnt fuses. I waited a bit and reconnected the battery and it started right up and I havent had a problem since. What would cause this? It's a brand new battery from Wallys Wolrd and I'm nervous it could happen again. Any suggestions.
HSkinner is offline   Reply With Quote
Old 04-10-2011, 07:39 PM   #2
jbgroby
jbgroby's Avatar
Re: I've got power coming out of the negative side of my battery???
Whoa, Freaky battery, better bring it back and cash in at wal=mart, must be defective to the extreme.
jbgroby is offline   Reply With Quote
Old 04-10-2011, 10:21 PM   #3
trevota
bad connection?????????
trevota is offline   Reply With Quote
Old 04-10-2011, 10:39 PM   #4
100%Chevy
I have to question what your meter was set on and where did you have your 2 meter leads to read power?
I suspect the initial no-start was a bad connection.
How you read power everywhere is not possible if you get nothing on the positive as the battery is the power source.
Mike.
100%Chevy is offline   Reply With Quote
Old 04-11-2011, 11:45 AM   #5
HSkinner
I was using a test light and nothing else.
Old 04-11-2011, 04:42 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Bad ground to the battery. I had something like that happen to me.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
