04-10-2011, 11:38 PM | #1 |
Turnsignal problems
Heres whats going on on my 1978 c10 and to begin all we did was replace the turnsignal switch and install lisence plate light. My left turnsignnal works, i put the right and both my blinkers flash and also my lisence plate light. Another thing. When i turn on my headlights, the right turn signal doesnt flash it just lights up like if it sticks, whats going on??? Help please. Thanx
Posted via Mobile Device |
04-11-2011, 12:27 AM | #2 |
BAD BOW-Silverado XST
Re: Turnsignal problems
If the light is on and but not blinking (dash green light), you have a bad bulb or ground somewhere.
04-11-2011, 01:40 AM | #3 |
I vote bad bulb
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
04-11-2011, 07:47 AM | #4 |
One shot, one kill.
Slick. The more wierd an electrical problem seems to be, EG, multiple systems affected as opposed to 1 thing not working, the more likely a ground problem exists. Check your grounds out back first. You replaced the license plate light so probably had to move the rear lighting harnace. Check the plug between the body and rear lighting harnace. This is a common failure point. Look for ANY green deposits in or around this plug. Next, if it has a trailer connection, look where it splices into the rear harnace for any green again. Repair the wireing as necessary and use heat shrink connectors wherever you have to resplice. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
