04-11-2011, 10:23 AM | #1 |
easiest way to remove the front clip
Hey Guys,
I will be installing a new engine and transmission next weekend along with getting the cab ready to remove and swap. What is the easiest way to remove the front clip as a single piece? where are the bolts located and if any of you have pics that would be great. |
04-11-2011, 10:29 AM | #2 | |
Re: easiest way to remove the front clip
04-11-2011, 10:40 AM | #3 | |
The Older Generation
There is also a bolt with a large washer on it inside each inner panel that threads into the sub frame. I believe they take a 5/8" socket. You also have to unbolt the wire loom from the firewall and remove the stiffener from the drivers side inner panel (around the steering shaft). plus the normal stuff like alternator wires, radiator hoses, trans cooler lines (if automatic), and windshield washer hose. It works best with 3 people, one for each side and a helper for the front where the radiator is. LockDoc
04-11-2011, 10:40 PM | #4 | |
04-23-2011, 04:23 PM | #5 | |
what I missing |
04-11-2011, 10:36 AM | #6 |
Junior Member
After removing the bolts we put the front end on jackstands and remove the tires, then three of us lift the front clip off.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-11-2011, 12:18 PM | #7 |
Moderator
Click on my build thread for removal of the front clip as one unit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-23-2011, 03:57 PM | #8 |
Restoration Virgin!
for anyone that's done this....have any issues with gaps once you put it back on??...I'm thinking of going this route when I pull the engine for a refresh on the gaskets (dang it!! wish I did this before) and install VA system
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-23-2011, 04:17 PM | #9 |
Moderator
Nope, this is exactly why I removed it as one unit. The only gaps you have to line up are the front fenders to the cab, and it is not too big of a deal. This way you do not have to line up the fenders, hood, grille, etc. This is the only way to go IMO.
04-23-2011, 04:33 PM | #10 |
Moderator
Here is what mine looked like when I pulled it.
04-28-2011, 12:55 AM | #11 |
saving
1969 Chevy c20(Miss Hackjob) |
04-28-2011, 09:16 AM | #12 |
dazed and confused
Me too
members met: redbaron69, billsbowtie,nc67 |
04-28-2011, 10:20 AM | #13 |
Why not just pull the core support and grille along with the hood.
Seems like a lot of work to get the whole clip off. I've swapped several motors in my impala and dad's chevelle, and only removed the core support and hood to do it. Only removed the hood on my impala, but it is a 96. |
04-28-2011, 04:27 PM | #14 |
Remove as one piece, but do not forget the ground strap....or that will hang the person up trying to lift up on the passenger side Bumper removal is a must too.
BTW Dave, if you need a hand and are going to do it on a Monday LMK and i can come by and help ya... |
04-28-2011, 09:20 PM | #15 |
Adam,
That would be cool, I can get lunch afterwards Last edited by frankenstein69; 04-28-2011 at 09:21 PM. |
04-29-2011, 03:47 AM | #16 |
turbo enthusiast
maybe a dumb question, but I suppose this works with a burb too?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting " |
04-30-2011, 08:58 PM | #17 |
Hey man, I am down to come help...can bring my buddy Richard too.. Cannot this Monday the 2nd, but definitely next Monday LMK....
Adam |
05-01-2011, 07:13 AM | #18 |
hell yeah, post pics of your swap!
05-01-2011, 08:04 AM | #19 |
I would have loved to removed my front clip all at once but my radiator support was shot.
05-03-2011, 02:38 PM | #20 |
Adam,
How does this Monday sound for you? David |
