![]() Join Date: Sep 2001
Windshield Channel - Being reproduced or donor?
I will post pictures later today or tomorrow. Have one tough spot, Passenger side upper corner.
I need to grind out the channel, POR-15 then prime. Some folks have suggested grinding, treating with POR-15 and then stuff it with JB Weld. I suppose that would work - it is just an epoxy. If I can put fresh metal in - then I would rather do that. Time to learn to weld. Would a stitch type welder work from Eastwood? Frank
Thanks, Frank |
1969 Custom 30 wrecker
Re: Windshield Channel - Being reproduced or donor?
If you mean the area above the windshield, that is available in repro for about $75.
I chose to just cut one out of a junker for my truck but it's not too easy and has alot of spot welds!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Thanks Bob.
I can't seen to find that patch panel. I will look later tonight. Frank
Thanks, Frank |
