04-14-2011, 06:35 PM | #1 |
LMC Rubber Body Mounts
Im looking for new body mounts for my 72 Blazer. Has anyone used the LMC rubber mounts or had any experiences with them??
Brad 72 Blazer CST 350/350/205 |
04-14-2011, 08:06 PM | #2 |
Re: LMC Rubber Body Mounts
I did a long time ago for my truck. They seemed to work well, but didn't come with any instructions. Just remember how you took them off, and you should be fine.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
04-14-2011, 08:29 PM | #3 |
Are they still holding up??
04-14-2011, 09:21 PM | #4 |
I just did a tech story for the July issue of Classic Trucks (not on sale yet) using LMC Truck's cab mounts on my '73 C10. Its pretty much the same approach to do the mounts on a '67-72. In addition to the rubber mounts, I used the optional urethane mounts that LMC sells as well. I can't tell you how well they'll hold up, but they do come with new bolts. That's a plus if yours are too rusted to reuse.
04-16-2011, 10:26 PM | #5 |
They've been doing fine, I haven't had any problems with them.
But, I haven't been to satisfied with stuff from LMC. Some of their replacement parts are plastic, whereas the OE equipment is metal. The plastic stuff just breaks to easily
04-14-2011, 10:39 PM | #6 |
I just installed a set of the LMC rubber mounts in my Blazer. Installation was straightforward and worked out well. The catalog has an illustration of mount part numbers and their locations on the chassis. The mounts come bagged by part number so they are easy to match with the proper location. The only thing I noticed was that the metal spacer sleeves that go inside the mounts were a thinner wall sleeve than the originals were. The new bolts that came with the kit are a necessity. I wouldn't have reused my old ones.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
04-15-2011, 12:10 AM | #7 |
Between Trucks...
I would get them from one of the Board vendors. The rubber stuff I've purchased from LMC was not very good.
Beat it to fit, Paint it to match... |
04-15-2011, 08:40 AM | #8 | |
I don't give d*** that the replacement rubber was free....it is my time and labor to take every d*** thing apart and re-install new rubber....I sure as h*** ain't gonna do it a THIRD time! ....well, not for another 30+ years Last edited by One Chevy Scotty; 04-15-2011 at 08:40 AM. |
04-15-2011, 09:13 AM | #9 |
Are you specifically talking body mount kits or weather stripping and window seals, because the original question was in regards to an LMC body mount kit?
04-15-2011, 10:02 AM | #10 |
Thanks for all the replies. I figgured Id ask because I had heard bad things about LMC rubber (mostly trim pieces), I just wanted to see if it was the same for their body mounts. They are like $100 cheaper in LMC so I wanted to poll the board before jumping.
04-15-2011, 11:28 AM | #11 |
Between Trucks...
I was referring to other rubber products I have gotten from them. Based on the quality of those pieces I would shop elsewhere.
04-15-2011, 01:16 PM | #12 | |
Just my .02 |
