04-15-2011, 01:37 PM | #1 |
Fan
My fan actually fell off this morning!! Looks like the clutch came apart.
Any way to bolt it solid with no clutch? |
04-15-2011, 01:42 PM | #2 |
Arrived on a Pale Horse
Re: Fan
Time to upgrade to electric fan. Non clutch/flex fans are too dangerous IMHO.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
04-15-2011, 02:39 PM | #3 |
Re: Fan
Just buy another clutch, unless you go electric.
The clutch will give you (SAP LESS) more power and economy then anything but an electric fan. It can be done, but you'd be downgrading a lot. |
04-15-2011, 10:35 PM | #4 |
Re: Fan
Didn't go thru the radiator at least!
04-18-2011, 07:35 AM | #5 |
Re: Fan
24.00 for a clutch and 99.00 for electric. That is soooo tempting!
04-18-2011, 10:44 AM | #6 |
El Mero Mero Frijolero!!
Re: Fan
Dude, get on Ebay or go to a junk yard and get a Ford Taurus Fan. They are cheap, work amazing, and easy to install.
My Toys: 1993 Ford Mustang LX 5.0 2001 Yamaha V Star 650 1984 Silverado > Build Page < |
04-18-2011, 11:28 AM | #7 |
Re: Fan
Pictures, additional info or a link if you would be so kind.
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
04-18-2011, 06:46 PM | #8 |
Re: Fan
http://cgi.ebay.com/ebaymotors/94-Fo...Q5fAccessories
This is the fan I use. Its easy to mount and wire up with a Autozone Universal fan kit. I did the whole swap for under $50.00 I think. I recommend it one hundred percent. I like that is thin and pulls air like crazy. Do it. lol
04-18-2011, 11:02 AM | #9 |
1962 C-10
Re: Fan
I prefer clutch fans. I got mine from the junkyard... very cheap.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
04-18-2011, 11:55 AM | #10 |
Re: Fan
Do a clutch fan with an auxiliary electric. Works really good when towing while its hot out.
04-18-2011, 07:39 PM | #11 |
BAD BOW-Silverado XST
Re: Fan
You live in hot climate. Better read this http://www.fordmuscle.com/archives/2...cfan/index.php
04-18-2011, 11:23 PM | #12 |
Re: Fan
Someone put a flex fan on my truck before I got it. Damned thing flew apart and chopped up a radiator hose, and then the balance issue must've caused the water pump to come apart somehow because it was leaking out of about 5 places. Bad news. Didn't know better but I do now. Picked up a stock clutch fan for $25 at a yard, and no problem since. Wouldn't mind an aux electric fan, just in case, but I hate trusting some little probably-China-made sensor that may or may not work to keep things cool when it matters. I like to think I check my gauges pretty often, but I can't sit and stare at them the whole time i'm driving to make sure everything is doing it's job. I like big, clunky, mechanical processes where if something's not working it's cause it's split in half or fell off. Easy to see, easy to fix.
04-20-2011, 11:51 PM | #13 |
Re: Fan
Traded my old valve covers, air cleaner and exhaust tips for a used fan and clutch. Back on the road again!!
