Old 04-16-2011, 12:17 PM   #1
Doug19
Interchangable Parts Chevy to GMC
So I own a 1966 3/4 ton GMC long bed. My plans were to make it into a short bed by cutting the frame and shortening the bed, but I stumbled upon a 1965 Chevy shortbed truck. Both trucks are in questionable shape. I want the finished truck to have the GMC 4 front light assembly. Basically I would like to know if I can transfer my GMC parts to the Chevy frame easily. I will use the chevy bed and maybe even cab depending on which on is in better condidtion. Will the front clip of the GMC easily transfer to the Chevy cab and frame?
Doug19 is offline   Reply With Quote
Old 04-16-2011, 01:29 PM   #2
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: Interchangable Parts Chevy to GMC
Will fit just fine. Earlier beds have different mounts but all shheetmetal should be fine.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 04-16-2011, 02:04 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
yes everything you want to do should work , the early style bed stopped at 62,, the dash and the inst. cluster part of the wiring harness will be different.
grille will plug into the chevy harness.
rear frame components are different because of the leaf rear in the gmc/vs the coil in the chev.
