Old 04-17-2011, 11:21 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Fitting 2.5 exhaust to stock ram's horn
I'm going to use my original 45* angled ramhorns and wanted to see what adaptors you'all are using.
Any ideas and / or links appreciated.
Thanks,
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-17-2011, 11:30 AM   #2
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Re: Fitting 2.5 exhaust to stock ram's horn
Im using Stock ram horns (straight dump 4x4) and would like to see this as well. I'm going to run 2.5" also
TTT
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 04-17-2011, 03:39 PM   #3
Dzlhead
I'd like to know also. I'm using my original 4x4 straight dumps, and hope to go with 2.5'', but on a Jimmy.
'66 C-10 Panel
'72 Jimmy 4x4
Dzlhead is offline   Reply With Quote
Old 04-17-2011, 06:20 PM   #4
Sport/Truck
Sierra Grande Club
IIRC the straight down rams horns are already 2.5 in?
I found this and think is might solve both our dilemmas.
http://www.castheads.com/corvette_systems.php
http://www.castheads.com/log_systems.php#manifolds
Old 04-17-2011, 07:09 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
I know on a buddies truck they went from 2" tube to 3" tube with...... Weld! They must have used half a roll of wire.
brad_man_72 is offline   Reply With Quote
Old 04-17-2011, 08:10 PM   #6
Sport/Truck
Sierra Grande Club
The options the muffler shops here aren't far from that!
I'm looking to have a clean transition and hope this will work for me.
Old 04-17-2011, 08:51 PM   #7
SCOTI
SCOTI's Avatar
Speedway Motors has a decent head pipe set-up w/a 2.5" flange....
http://www.speedwaymotors.com/Tight-...-Kit,1722.html
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-21-2012, 02:04 PM   #8
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Curious if anyone ended up buying the adapter kits above.
Also, do you use special hardware for attaching the ram horns to the heads or just plain bolts, Grade 8?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 08-21-2012, 09:28 PM   #9
70CHEVYBB
70CHEVYBB's Avatar
who's doing your exhaust (home build or muffler shop)? I have been working at a Meineke for 24 years, just a guess but I have probably custom bent exhaust for 100 plus 67-72 chevy trucks. All I do is use a 2" reducer after I bend the front pipes,flare it for the donut and press in a piece of 2" to make the donut sleeve. very simple process.
Wes
70CHEVYBB is offline   Reply With Quote
manifold, manifold adaptors, ram's horns, ramhorns
