![]() Join Date: Sep 2002
Certifiably crazy person |
Fabricate till you "puke"
between 69 & 71 chevy, the pcs should be a direct bolt on. the grills should swap(same fenders). Bumpers/ brackets will be different ,as the 71 has the blinks in the bumper. Other than that, you may find some differences in the wiring harness, & rear cab cushions(1/2 to 3/4 ton). Good luck,crazyL
Resident Curmudgeon
![]() Join Date: Dec 1999
The suspension components on a 3/4 ton are different (ball joints, tie rods, brakes,etc) but nothing is different in the items you listed.
Regarding the cab, you will have to swap out your 71-style cable throttle linkage to the rod-style linkage on the 69. Look at the firewall where the throttle linkage components are located and you'll see the differences. I have a few left over AZ used sheetmetal pieces here if you need front fenders or radiator supports.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
A$$ deep into trucks
As far as interchange goes, the 69 cab will replace your 71
with no major problems. The throttle cable/rod difference is easily addressed, and you can use the 71 1/2 ton 2WD type rubber mounts. I would suggest using all of your 71 wiring, unless, of course, the 69 has AC, then go with the harness that has the options that you want to add. All front sheetmetal will swap over, also. Rear stepside fenders, I believe, are the same, but, of course the steps are different. Column, P.S. box, sway bar are same. A- frames upper and lower are same, but ball joints, and steering linkage varies from year to year. As far as cabs go, technically, 67 is by itself, as well as 68. 69 & 70, as far as I have determined, are the only identical 2. 71 is a one year only cab, same for 72. They will all swap around, but there are small differences in appearances. The easiest to swap are 67 for 68, 69 for 70, 71 for 72. 69 through 72 are second easiest, with 67 for 72 being the most difficult to make functional. (E-brake, flow through vent, guages, etc. Sounds like you are looking at a fairly easy one.
hardrock2 |
