Old 04-19-2011, 10:15 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
LSx Exhaust flanges / collector flanges
What are you guys using for exhaust flanges off of stock manifolds?
The tbss manifolds I have use a 3 bolt pattern, but its not a standard bolt circle. What are you guys using to connect your stock manifolds to the rest of the exhaust system?
My only thought is to track down a set of junkyard cats, and have them cut off the flanges and a stub of piping, and use that to start my exhaust from. I'd appreciate some suggestions.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-19-2011, 10:22 AM   #2
faribran
Re: LSx Exhaust flanges / collector flanges
i thought it was a bit strange.. but the guys on one of the Sunday TV shows just "whacked" off the original flange and welded on an extention of pipe(the manifolds are steel, not cast, so they said) for what its worth...
faribran is offline   Reply With Quote
Old 04-19-2011, 10:43 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've heard that mentioned as well, mainly from the turbo guys putting vbands on them. I'm plenty capably of welding exhaust piping, but welding that thick manifold steel is probably above my skill level, was hoping for a flange to start with.
Old 04-19-2011, 03:24 PM   #4
harnalien
TruckincrazY
harnalien's Avatar
This is a big obstacle I'm trying to overcome as well. When I call around to yards, they don't seem to know what I'm talking about. I just ordered these from eBay http://cgi.ebay.com/ebaymotors/2-5-3...item3f0939549e. I haven't tried them yet but have my fingers crossed
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 04-19-2011, 04:32 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
hmm. Those look like regular 3" bolt circle flanges, are you thinking you can elongate a hole to get it to work or something?
I'm going to see if they will cut me a "stub" off of the exhaust, I might be able to get the 02 bungs in there if im lucky. Do you know if the truck exhaust and the tbss exhaust pattern are different?
Old 04-19-2011, 07:08 PM   #6
harnalien
TruckincrazY
harnalien's Avatar
I really don't know if there is a difference between the tbss and truck manifolds. I've got a bad feeling these flanges won't work, but I'm getting desperate. I may just have to have the exhaust shop make me some or start calling yards again.
Old 04-19-2011, 08:18 PM   #7
TR65
TR65's Avatar
I used the stock pipes from the manifolds to the back of the cab. I have SSR exhaust manifolds, the same as Trailblazer SS I think. They used a regular exhaust biscuit on one side for a seal and a copper o-ring on the other side. Made a very solid connection. So using stubs off of a stock rig should make a good system.
Amazingly in my case the stock pipes, cats, and all perfectly fit in my C10. No modifications required. I just hooked up to the outlet flange at the back of the cab.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 04-19-2011, 09:48 PM   #8
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
The passengers side flange is symmetrical, but the drivers side is a bit odd.
https://dragtimes.com/parts/LS1-Exha...641553675.html
I'm currently in need of a drivers side...
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-19-2011, 10:46 PM   #9
harnalien
TruckincrazY
harnalien's Avatar
So those in the link will work for sure?
Old 04-19-2011, 11:23 PM   #10
85burb
85burb's Avatar
I went to every shop in town that did exhaust and none had a pattern or anything that would work. I went to a junk yard and took some off a motor they had on a shelf. They did not even know what i was talking about. It is just best to go walk the yards calling is mostly a waste of time around this area. Only gave 10 bucks for the set.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-19-2011, 11:25 PM   #11
usmcchevy
usmcchevy's Avatar
That is the pattern that the Van, trucks and TBSS use.....I don't have any car manifolds here to check them.
Problem that I see with cut flanges like that is, how do you seal them? Factory flanges have a grove for a seal, those don't.
Build thread
LSx Swap FAQ index
Old 04-20-2011, 12:18 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
u could use sheet copper and do a flat gasket
Old 04-20-2011, 03:37 PM   #13
usmcchevy
usmcchevy's Avatar
Looks like GM used the same flanges on all of the trucks. Got one off of a 00 GMC 1500 with a 4.3 V6. Just laying on the ground next to the truck like it was ment to be mine $2
Build thread
LSx Swap FAQ index
Old 04-20-2011, 03:49 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I found the flanges in raw steel (as priced) or avail. in stainless
from spd exhaust
F5172109 $36.70 each
F5162109 $33.25 each
Those are the part numbers for the drivers and passenger flanges. I haven't ordered them yet, as I have a junkyard trip coming this week, and I'm going to see if i can get them on the cheap.
Old 04-20-2011, 07:56 PM   #15
harnalien
TruckincrazY
harnalien's Avatar
Would these work?
http://cgi.ebay.com/ebaymotors/Ls1-f...Q5fAccessories
Old 04-20-2011, 11:02 PM   #16
ls1nova71
ls1nova71's Avatar
Those will only work if you have F-body manifolds, won't fit truck manifolds.
But as a side note, they're not hard to make, provided you have a torch a drill and a die grinder. You can make just the flange, like the ones you put the link to, then go to a muffler shop and find a donut gasket that will fit in the end of the manifold, it doesn't have to fit tight, but it does help when installing them if they stay in by themself, then get some exhaust pipe a foot long or so, and have them flare the end to match the donut gasket you just got, slide the flange over the pipe and bolt it to the manifold with the donut gasket in between. This seems to work better than a flat gasket because it's not trying to bolt the whole exhaust pipe up flush with the manifold, it gives you some ''wiggle room'', then when you tighten them up you're good to go. This pipe is also a good place to put your O2 bungs in if you cant use the location in the manifolds. Muffler shops sell them pretty cheap.
ls1nova71 is offline   Reply With Quote
Old 04-21-2011, 12:21 AM   #17
softballnrd27
Always a work in progress
softballnrd27's Avatar
Just put a v-band flange on it and call it good. These manifolds weld very easy, just preheat and then let them cool in the oven.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 04-21-2011, 09:25 AM   #18
harnalien
TruckincrazY
harnalien's Avatar
ok, last try before i hit the yards again. what about these?
http://cgi.ebay.com/ebaymotors/LS1-E...item4158a0fd88
Old 04-21-2011, 10:07 AM   #19
ls1nova71
ls1nova71's Avatar
Yes, those will work for truck manifolds. You are looking for truck flanges right? I just realized this thread is kind of generic, and when you posted the last link, I just assumed you were wanting truck manifold flanges.
Old 04-21-2011, 10:12 AM   #20
Clyde65
Clyde65's Avatar
Harnalien, I thought you had headers?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-21-2011, 12:22 PM   #21
harnalien
TruckincrazY
harnalien's Avatar
Yes i'm working with the stock truck manifolds. I'd like to have headers, but the ones that are known to fit are way out of budget. there are some other cheaper headers that some say work, but I can't afford to take chances buying something that may or may not work. I would love to find the stock flanges with the pipe down to the o2 sensor, but my plan for now is to use those flanges and have an exhaust shop build off of those and mate to my existing exhaust.
Old 04-21-2011, 12:43 PM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
hmm that ebay link ain't bad, about 1/2 the price of the spd ones I found. I'm hitting the yard tonighte, so if i strike out there, I may have to use those.
Old 04-22-2011, 12:47 AM   #23
67shortie
Green club
67shortie's Avatar
If this will be of any help, the TBSS manifold I used worked with standard truck flanges that the exhaust shop had in a big box of stuff they had lying around. I guess I got a little lucky with that. they are different one is more triangle style and one is more unsymetrical like the 2 bottom holes are closer together like a skinny pyramid style.
They used 2 different style of gaskets one used a small donut style of gasket and the other used a rolled steel compressable ring. Doesn't leak, and the gaskets were only $9 for both.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 04-22-2011, 10:45 AM   #24
harnalien
TruckincrazY
harnalien's Avatar
Well I broke down and bought some Schoenfeld headers. I read a few build threads on here and other sites and they should work. I figure they are priced nice and by the time I buy different flanges hoping they work then try and get an exhaust shop to piece something together, I've spent just about the same amount ad the headers of not more. I should have them on by the beginning of next week.
Old 04-22-2011, 11:12 AM   #25
Clyde65
Clyde65's Avatar
Harnalien,
Please explain to your wife, I had nothing to do with that decision.
Clyde65
Rebuild of Clyde
support our troops!
