Old 04-19-2011, 02:52 PM   #1
72smoker
72smoker's Avatar
72' 2wd tire size?
What do you guys run for tire size on your 2wd trucks? I would like to run a 12.5 in the rear but im not sure of the height. Any suggestions pictures would be great. thanks in advance.
72smoker is offline   Reply With Quote
Old 04-19-2011, 02:55 PM   #2
6772owner
Gearhead
6772owner's Avatar
Re: 72' 2wd tire size?
I currently run 255/55/18's, but would like to do a 285, 295, or 305 when I go to new wheels. This is on the 72' in my sig, rear is lowered about 6-7" at ride height. I do run 1.25" rear spacers because of the offset on my wheels. (Which I bought when it was still a stepside box)
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-19-2011, 08:15 PM   #3
72smoker
72smoker's Avatar
285's looked a little big on the fornt I thought. It has 31's on it now that look big up front but that might change once I decide on the rim to use.
Old 04-19-2011, 08:30 PM   #4
70cst
70cst's Avatar
I agree...
I had 285x60x16" on the front and in my humble opinion way to big. I switched to 15" wheels and bought 225x60x15's fro the frontbut--. too small and I will likely end up with 245x60x15" on the front and 275x60c15's on the back. Good luck with your tire selection.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-22-2011, 10:17 AM   #5
stich626
Originally Posted by 70cst View Post
I agree...
FYI 245/60/15 IS TO SMALL up front they are on my truck now and look tiny(mine is not lowered)
I'll be going to 255/60/15 if I stay at 15"
eye'n 17" rallyes but can't find 17" that are taller than rubberbands and wide
as I like my 295/50/15's in the rear and I'd like a little taller here also
stich626 is offline   Reply With Quote
Old 04-22-2011, 10:33 AM   #6
70cst
70cst's Avatar
Thanks for the info...
As mentioned 225's are way to small and I need to look at a larger 15" front tire. Why 15's...I want to be period correct as in the 70's 17" and 20" wheels were not available...but I do like the larger wheels on our trucks.
Old 04-22-2011, 11:02 AM   #7
stich626
thats why I'm eye'n the 16-17" chevy steel rallye's
unless you really look it'll look ole school.. and I not want to run rubberbands up here (pot hole city)
i'll more than likely stick with 15" as finding tall/wide 16/17 isn't all that easy, nor cheap..
Old 04-19-2011, 08:54 PM   #8
72smoker
72smoker's Avatar
I would never have thought that tire size would be so hard to figure out but every truck I have ever owned has been 4-wheel drive.(Bigger is allways better) This is my first 2-wd and a 72 at that. I would like to get it right the first time given the cost of every thing.
Old 04-20-2011, 12:46 AM   #9
OARNGESI
OARNGESI's Avatar
I got 295 50 15 and 245 60 15
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-20-2011, 08:10 AM   #10
68Stepbed
68Stepbed's Avatar
Are you wanting to stay with 15" wheels? Is your truck lowered or do you plan to lower it?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-22-2011, 10:12 AM   #11
72smoker
72smoker's Avatar
I was thinking that I would go with a 17" or 18" wheel. It has 16.5 steels on it now with 30" tires. It dose have bags on it and I would like to have it ride lowered.
Old 04-22-2011, 01:20 PM   #12
68Stepbed
68Stepbed's Avatar
I beleive a 29-30" tire in the rear and a 27-28" front tire looks best on these trucks.
I'm running 17x8 with 255/50/17(28") tires up front and 17x9.5 with 275/55/17(29") tires in the rear with a 3.5/5 drop on my 68. I would liked to have had a slightly taller tire in the front, but it's just hard to find matching staggered tires in 17". I wished I'd went with 18's. 18" tires are much easier to find in the sizes I wanted.
Matt
Old 04-25-2011, 07:45 PM   #13
72smoker
72smoker's Avatar
68stepbed I like the way the tires look on your truck. The more I look 18" rims are most likley the way I will go. Pictures help allot, the more the better. Thanks guys.
Old 04-25-2011, 08:08 PM   #14
67swb72klb
67swb72klb's Avatar
275 60 15
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-22-2011, 08:44 AM   #15
72smoker
72smoker's Avatar
I think that I finally found the wheels and tires I want on my truck but I'm not sure if the 4.5" back spacing will work. Front's are 17x8 with 235/65 17 (29x9) tire. Rear's are 285/60 17 (30.4x11.4) tire. Will the 11.5 work in the rear and will the 9" wide hit when I turn up front? Thanks for any help.
Old 07-22-2011, 05:28 PM   #16
68Stepbed
68Stepbed's Avatar
The 4.5" bs should be fine. Is your truck lowered? If so, how much?
Matt
Old 07-23-2011, 08:14 AM   #17
72smoker
72smoker's Avatar
It is set up on bags so the ride height is not really a problem. I would like to have it ride lower but not slammed.
Old 07-23-2011, 08:51 AM   #18
68Stepbed
68Stepbed's Avatar
OK the 4.5" backspacing should be fine. In fact it will help tuck the wheel in more to keep the tire from rubbing the outer edges. I'm just worried about the height of the tire. At 29" tall, you may encounter some rubbing, but since it's bagged, you can just raise it up some in the front when driving.
There's a member here, I beleive his board name is "dmwphoto". He was running a similar size tire combo. Try searching and see if you can find the thread he has about his tires and drop.
Matt
Old 07-23-2011, 09:20 AM   #19
68Stepbed
68Stepbed's Avatar
OK I did a search. Here's the link. http://67-72chevytrucks.com/vboard/s...d.php?t=428284
He actually switched to a 235/60/17 in the front to fix his rubbing issue, so it looks like you will be in good shape.
Matt
Old 07-26-2011, 07:32 AM   #20
72smoker
72smoker's Avatar
It sounds like I will be ok. Thanks for all the help 68stepbed.
Old 04-25-2012, 09:31 PM   #21
72smoker
72smoker's Avatar
I hate to beat the whole wheel and tire thing to death but I have another question as well. I went to order my wheels and they don't make the 17x8 wheels. The question that I have is, will a 17x9 4.5 back spacing work with a 27" or 28" tire up front? I really like these wheel and can't seem to find any others I like. Procomp 8101 wheels. Thanks for any help.
Old 04-25-2012, 09:44 PM   #22
72smoker
72smoker's Avatar
Here is a link.http://http://images.search.yahoo.co..._33XX_A_PG.htm
