Still Learning
Where did you buy your brake line kit? Did you like?
I need to find a brake line kit for my project. Where did you guys buy your's? Did you like it? were the bends close? I have heard some pretty good stuff about Inline but the price ain't cheap. I'm on a super tight budget but I may have pony up to get some good lines. Anyone used LMC or similar company products? any suggestions welcome.
![]() Join Date: Mar 2000
Re: Where did you buy your brake line kit? Did you like?
I used Inline on my 92 and it fit perfect.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 04-19-2011 at 04:37 PM. |
![]() Join Date: Jul 2000
Mike, I have used "Classic Tube" and "The Right Stuff". I am happy with both. Last time I used Classic Tube because the fittings were also stainless and its only 80 miles from me. Good Luck! Terry
50 miles west of Syracuse, NY '94 Silverado swb '70 Chevelle '65 Corvette roadster '11 Tahoe (wifes ride) |
Restoration Virgin!
Mike...when I ordered mine from LMC light years ago....they were from Inline tube
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
interested also
1969 Chevy c20(Miss Hackjob) |
I have used Inline Tube a couple of times. Classic Tube is only about 10 miles from me, but their stainless complete brake line kit is listed at $299 online as opposed to Inline's $185. Maybe they include more - I don't know. Inline did send me the wrong front lines for my 70 4X4 when I was doing that, but they rectified the problem quickly and didn't want the wrong lines back. I have since found out that they were for a 71 as they will fit my 71 Blazer (current project).
Hey Terry (WILLNIK) -hello to another Western (well Central almost) New Yorker. Think we've met and spoken before if you had a Blue and White Chevy for sale a couple of years ago. Rick
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 04-19-2011 at 09:08 PM. |
Moderator
![]() Join Date: May 2007
I got mine from the Truck Shop in Orange. They worked out great....but beware that some of the lines will be "bent" to make them fit in a shipping box, so they will need some straightening and additional bending when you set them up. I believe this is how the manufacturer sells them to ALL the vendors. I bought mine at the counter and they were still bent to fit in a box.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Man of Mini-Talents
I got the lines for my 72 from Inline also. Fit was right on, as was the fuel line from pump to carb.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
![]() Join Date: Sep 2005
i used inline tube only part that didn;t fit was the axle tubes but that was becasu ei had a different rear end under mine
Still Learning
Hey, I am in the process of finishing my rear end install. I used a 73-87 style 12 bolt differential. So are the fittings different? or did the lines bend different? thanks
Keep Your Nose Clean
I got mine at inlinetube.com They are stainless prebent and fit great. check out my build for pics. They cost a bit more than other places, but well worth it.
Still Learning
Okay, Thanks to everyone for their comments. So consensus pretty much says inline tube. So, what about stainless versus the oem steel? the price is the $30 bucks extra worth it? I have heard of issues with sealing the SS line. Also, doesn't inline tube nickel and dime you to death for all the "hardware" that's not included with the $185 kit?
Dang, that sure seems like a bunch of cash for tubing and fittings. Anyone built their own lines with a hand bender? Bet that takes some serious time, not to mention cutting and re-doing lines multiple times. |
Just a car guy
Great expereinces from online tube as well.
Classic tube outright lied to me several times over an order from brakelines for a 197; chevy truck Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
InLine Tubes via GMC Pauls. Didn't fit like originals, had to do a bunch of rebending. They are stainless. Should have bought straight sections of stainless and bent the brake lines myself, would have turned out better, taken less time and cost less.
#15 |
Still Learning
Was it the front or back you had to tweak to make fit? or both?
#16 |
Had to bend the 3/16 & 1/4 lines in the front. Had to bend the 1/4 line that runs down the passengers side of the frame. I'm still not finished, after I get my cab remounted and my master cylinder mounted I will need to finish bending the lined to connect to the master cylinder. Really unhappy with the lines.
#17 |
Inline tube here also, no complaints, fit great. Did have to buy a mounting clip kit. I got my fuel lines and trans cooling lines from there also. All fit great.
#18 |
I do all of mine myself out of polyarmor
#19 |
Still Learning
That stuff looks pretty tough. Where do you buy it? where do you get the fittings from? Can you buy a kit for our trucks?
#20 |
#21 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Stay away from Classic Tube. Sent lines that didnt fit the differential, had to send my origionals (at my expense) for them to copy. Made it seem that the poor fit was my fault. I would not deal with again.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#22 |
wanna be 67
Inline and SS fit perfectly
Posted via Mobile Device Last edited by 19stepSide72; 04-21-2011 at 11:31 AM. Reason: Spelling |
#23 |
Still Learning
Okay,
I got my inline tubes in yesterday. Only problem I don't know for sure where the lines go. My frame was completely bare when I got it. Anyone, have some pics of the rear end installed? thanks |
#24 | |
Old Skool Club
![]() Join Date: Jun 2001
Does that help?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#25 | |
Still Learning
![]() the kit is 11 pieces and I would like to mount them in the "correct" location if you know what I mean. |
