04-20-2011, 06:06 PM | #1 |
Rear coil spring lower retaining bolt
How can I get the rear coil spring, lower retaining bolt out? The heads twisted right off. I tried a punch and hammer and it is rusted in real good.
04-20-2011, 06:30 PM | #2 |
Redefining LowBudget
Re: Rear coil spring lower retaining bolt
been there done that if the spring is still hooked at the top your in good shape ...un hook the shock.... jack it up by the frame till the wheel is a couple inchs off the ground then get a BFH and let it have it...I ussually try it dry and the rust and crap will rattle out while the weight of the axle ill help pull it out...not fun and you'll find out what shape your trailing arms are in after you beat the rust out of them
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
04-21-2011, 02:30 PM | #3 |
Same thing happened to me. I was replacing the springs anyways so I just used a cutoff wheel and cut the springs out and then ground the nut flush and popped it out with a punch and hammer.
2007 Chevy 2500HD all stock 1985 Chevy Blazer- sold 1971 Chevy c10- The Mistress 2014 Ford Interceptor SUV |
04-21-2011, 06:27 PM | #4 |
Grandpa in the rustmobile...
saw zall
my favorite tool in the shop
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-21-2011, 07:46 PM | #5 |
to get mine out i had to use a torch! cut all the heads off the bolts and then just used a grade 8 THICK washer to fix the melted part of the hold down cups
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
04-21-2011, 08:25 PM | #6 |
Old Skool Club
Take the rear end out, turn it upside down, and it's a lot easier....just sayin'.
Seriously, one side of mine was not cooperating. Had to take it out anyway and it sure went alot easier when it was upside down. Wouldn't recommend doing it that way if you didn't need to do what we planned.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
04-22-2011, 05:36 AM | #7 |
ChevLoRay, you win the prize. It is out of the truck. I turned it up side down and beat it out with a hammer and punch. Thanks
