Old 04-21-2011, 04:52 PM   #1
FFredo
Well that was a bust "wheels for my 59"
Just venting, I scored on a set of 5 15X8 6 lug wheels. Unfortunately because of the 72 jimmy rear end in my truck they will not fit under the wheel wells. I'm not willing to change out rear ends to get the wheels to fit.
maybe I can turn them into bar stools.....
FFredo is offline   Reply With Quote
Old 04-21-2011, 05:11 PM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: Well that was a bust "wheels for my 59"
so you have a 4wd axle under a 2wd? I know they make 1.5" spacers that us 73-87/91 guys use to make the front and rear widths the same, maybe look into that route?
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 04-21-2011, 05:18 PM   #3
hotrodhomi
hotrodhomi's Avatar
If you do use "spacers" I would use the type that bolt on. Most places call them adapters. They make 5x5 to 5x5 or what ever pattern you use. most are 1.25" think but they offer thinker and thinner varieties.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-21-2011, 05:32 PM   #4
Walts_restoration
what hotrodhomi said, those would be the kind i would use.
Old 04-21-2011, 06:02 PM   #5
BlueJeep
BlueJeep's Avatar
I assume he means they stick out too far, so the spacers wouldn't solve the problem. He said 72 rear end in a 59.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 04-21-2011, 06:20 PM   #6
FFredo
This:
Yeah Bluejeep has it right, the newer rear end on the truck makes it about and inch too wide to run the 15X8s i picked up. Just limits my choices for wheels is all.
Like I said I'm just venting, nice wheels though.
Old 04-21-2011, 07:16 PM   #7
mr48chev
mr48chev's Avatar
If they are steel wheels you might think about having someone cut the centers out and move them out a bit increasing the back spacing. It wouldn't take all that much an the only real issue would be that you couldn't rotate the tires unless you did the fronts too. You would have to calculate how much room you had to do it though as some wide rims already have a fairly deep backspacing and might hit the tie rod ends if they go further.
Old 04-22-2011, 05:34 AM   #8
craig32
I have the same sitch with my truck. It has a wider rear from a (whatever) under it, and it has lift blocks between the springs and axle. I'd like to take them out and lower the back, but then the tires would hit the fenders. Not sure if they were stock with the rear axle, but they make the 31" tires fit.
craig32 is offline   Reply With Quote
