04-21-2011, 06:22 PM | #1 |
Thoughts and ideas needed......
A buddy has my old 62 K10, and needs front axle. We found a matched set from a 90 Blazer, 10 bolt 3.42"s with springs. Good swap? The price is right.
1962 Chevy K10 factory 4x4 stepside longbed http://67-72chevytrucks.com/vboard/s...d.php?t=494632 1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded 1968 Chevy 1/2 ton panel wagon, V8 and powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=483345 1978 Ford F250, beater stepside 2008 Jeep Wrangler 4 Door 2010 Chevy 4x4 plain jane work truck |
04-22-2011, 01:04 AM | #2 |
60-66 Nut
Re: Thoughts and ideas needed......
It depends on what the '62 is being used for. The 10 bolts are good for most uses, but if he is beating on them with big tires mounted to them, they may not last long. Also the 3.42 gears may or may not be what he needs , there again depending on the size of tires, and the transmission in use. Basically need a little more info.
04-22-2011, 09:17 AM | #3 |
It's not going to be a trail rig or jacked up. He's going to use it to beat around in, short trips to town, and on his place. It's got the 235 and 420 transmission. Has new 10.50x15 mud terrains on it. Nothing fancy.
Thanks.
04-23-2011, 12:32 AM | #4 |
60-66 Nut
Those should be a good set of axles for that application then.
04-23-2011, 11:46 PM | #5 |
Thanks. I think he's picking them up Monday.
