04-21-2011, 10:25 PM | #1 |
How to open hood latch
I was going to take apart the 87 front clip I bought today and cam across a problem. The guy I bought it from removed the hood release cable and latched the hood completely down. I don't see any way to get to it to release it. Any suggestions?
Posted via Mobile Device |
04-21-2011, 11:16 PM | #2 |
Re: How to open hood latch
I assume your looking at just a front clip not bolted to a truck. Its pretty easy. follow to where the cable hooks to move that lever with a screwdriver or whatever else you can reach it with.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
04-22-2011, 08:57 AM | #3 |
Maybe i need to set the clip flat. It is standing on it's end right not and I couldn't see any way to get to the lock.
04-22-2011, 09:11 AM | #4 |
If you're not sure where the cable hooks up, maybe take a look at another truck like the one you're looking at. Just make sure the owner isn't watching, so you don't get shot...
04-22-2011, 01:04 PM | #5 |
I did this when I was painting my truck, I had to burn out the bolts with a torch. We then drilled a hole under the lever so we could unlatch it with a screw driver.
04-22-2011, 04:22 PM | #6 |
78K & 79C Jimmys
can you get the grill out?to reach up
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-22-2011, 08:31 PM | #7 |
In the assembly plant we used to use a piece of flat sheetmetal cut into a "hook" shape.
You slide the hook between the hood and the top of the radiator support, grab ahold of the latch lever (where the cable connects) and pop it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-22-2011, 09:48 PM | #8 | |
