Old 04-22-2011, 04:13 AM   #1
Mt Man Chad
Mt Man Chad's Avatar
What to use for lubricant?
Putting the 327 and SM465/NP205 setup together for the 68 4X4 burb.
What is the correct lubricant to use on the clutch splines and throw out bearing?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 04-22-2011, 07:00 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: What to use for lubricant?
nothing!! I never put anything on them since the dust would collect on them and might make them stick.....kinda like brake adjusters....I do put a dab of grease in the pilot bushing/bearing but it more of a help assemble thing
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-22-2011, 09:45 AM   #3
OJ1988
Just a car guy
OJ1988's Avatar
Don't want that lube slinging out and getting on flywheel or clutch friction surfaces either.
If anything, maybe a dab of anti seize?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 04-22-2011, 11:40 AM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
John
1999 Toyota Tacoma 4x4
Old 04-22-2011, 12:11 PM   #5
rsavage
rsavage's Avatar
I would replace the throwout bearing at the least before putting it back together. The clutch fingers look like they have some wear on them, and I believe the original type clutch would have been a diaphragm, so if you don't know how good the clutch is you might want to replace the works and get the flywheel surfaced. I know, one thing leads to another on these, but it is a lot easier to do it once.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-22-2011, 01:05 PM   #6
AirSpeed
AirSpeed's Avatar
I second that! I made the mistake of not replacing the clutch and throw out bearing when I was a kid, I replaced the engine in a 70 I used to have, about a month later the bearing took a dump and I had to pull the transmission outside, in the rain, in the dirt! The parts aren't that expensive, replace them now or you may end up pulling it apart later!
AirSpeed is offline   Reply With Quote
Old 04-22-2011, 01:06 PM   #7
Hottrucks
Hottrucks's Avatar
3rd
Old 04-22-2011, 02:05 PM   #8
Mt Man Chad
Thx!
Old 04-22-2011, 09:22 PM   #9
hayhauler71
hayhauler71's Avatar
A very light coat of high temp wheel bearing grease on the input shaft where the throw out bearing slides and also the splines where the disc rides.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-22-2011, 09:38 PM   #10
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Thats what I do too.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 04-23-2011, 12:45 AM   #11
70cst
70cst's Avatar
Will move to Burb forum...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-23-2011, 01:50 AM   #12
vectorit
What?
vectorit's Avatar
I just dab a tiny bit of graphite on the pilot bearing, and a light brush of high temp grease on the input shaft where the clutch disc slides.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
