Old 04-22-2011, 04:39 PM   #1
gimmy 64
gmc leaf springs
need help from gmc guy's, does any one have picture of how there leaf springs are mounted. i need to know what the bracket that the u-bolts mount to look like. i know that my truck is not right and want to make sure that it right. thanks
gimmy 64 is offline   Reply With Quote
Old 04-22-2011, 05:46 PM   #2
FetchMeAPepsi
FetchMeAPepsi's Avatar
Re: gmc leaf springs
Like this?
FetchMeAPepsi is offline   Reply With Quote
Old 04-22-2011, 05:53 PM   #3
gimmy 64
what year is your truck? that doesn,t look any thing like mine. mine is a 64 thanks
Old 04-22-2011, 06:00 PM   #4
FetchMeAPepsi
I didn't think they'd be different. I'm scouring the build threads for a 64 now.
Old 04-22-2011, 06:15 PM   #5
FetchMeAPepsi
None of these are terriffic, but they might let you see what you're wanting.
This one's a 4x4. Still looking for a 2wd
Old 04-22-2011, 06:20 PM   #6
FetchMeAPepsi
2WD (thanks to Nachodog)
that's all I could find that was 1964 specific. If that doesnt work I'm sure someone else will chime in.
Old 04-22-2011, 08:52 PM   #7
padresag
this one is haywire unless those are brackets welded to the bottom of the axle hsg. would have been cleaner if he had taken the spring perches off the top then he could have just welded them back on the bottom. hope that he has a facility for the centre bolt. difficult to see. what are you trying to accomplish?
ron
padresag is offline   Reply With Quote
Old 04-22-2011, 09:40 PM   #8
nachodog2
Hell yeah!!!
nachodog2's Avatar
ron
Top perches are gone now, bottom brackets welded, this is temporary any way. I'm stepping up to a 4 link pretty soon. Have had had no problems with it.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 04-22-2011, 10:28 PM   #9
padresag
I have seen where people leave things like that. it can be taken out of context when they are inserted in a thread like that. glad that you were not finished there. I was asking what the original poster was trying to accomplish
ron
Old 04-22-2011, 07:04 PM   #10
creep
Registered Loser
creep's Avatar
Here's a pic from my 63 3/4 ton. Hope it helps.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-22-2011, 07:09 PM   #11
gimmy 64
creep do you have a picture of the bracket where the u-bolts go yours looks like mine should be thanks
Old 04-22-2011, 07:14 PM   #12
creep
Registered Loser
creep's Avatar
Unfortunately no. I gave the rearend away to the guy that did the welding on my frame when I bagged mine. I'll try and find out if he still has them.
Old 04-22-2011, 10:28 PM   #13
padresag
what are you trying to accomplish??
ron
Old 04-23-2011, 07:10 AM   #14
biohazardbill
I found some I took off my GMC, if u need em let me know, I have no use for them.
biohazardbill is offline   Reply With Quote
Old 04-23-2011, 09:50 AM   #15
1stseries55
1stseries55's Avatar
not trying to hijack or anything....but where did you GMC guys find replacement bushings for the leaf spring eyes?..... I have not been able to locate any.
Jared
USMC 1st Battalion 8th Marines (95-99)
55 1st Series 3100 (on 98 sonoma frame)
65 GMC short bed fleetside big back window
http://67-72chevytrucks.com/vboard/s...d.php?t=358493
1stseries55 is offline   Reply With Quote
Old 04-24-2011, 06:03 PM   #16
gimmy 64
the way my leaf springs are mounted is like the newer leaf spring trucks are done. i ordered new u-bolts for my truck and they came square on top to be mounted over the top of the springs. what i need is to see what the bottom plate looks like that th u-bolts mount to. heres pictures of how my rear end is mounted now. thanks
Old 04-24-2011, 09:32 PM   #17
padresag
here is what you should have. look like someone has snuck in a car rear end and bastardized the setup by putting all the wrong crap in there. the plates are wrong as the ubolts should be in tight to the springs. the hole is to large for the centre bolt. the spring perches should have been removed from the axle hsng
By rondavid at 2011-04-24
the top of your springs should be square as they form over the top of your spring and connect into the brkts shown mounted under the axle
ron
Old 04-25-2011, 10:16 AM   #18
monolith
Zero Albedo
monolith's Avatar
My 64 1/2 ton:
Hope these pics help!
Baz
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 04-25-2011, 06:38 PM   #19
gimmy 64
ok that is what i was looking for. now does anybody know where i can get the bottom brackets? thanks
