04-22-2011, 05:55 PM | #1 |
radio installation
Bought an Alpine radio for 64 Corvair today. To wire I have a question.
The radio has wires for a remote turn on, a audio interrupt in. a power antenna, a Illumination, a ignition, a battery and a ground. My question is can I just disregard the remote turn on, a audio interrupt in. a power antenna? And connect the Illumination, ignition, and battery wires together to the hot wire for the radio in the car? I will ground the ground wire to the frame?
Chief mechanic for my, 54 Belair, 64 Corvair, 72 C/10Fleetside and 2002Tahoe. John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me. My Book "Why Cancer is Not Bad Luck" by WestBow press |
04-22-2011, 06:43 PM | #2 |
Re: radio installation
if a radio has a remote turn on..you have to have it hook up or it wont come on..even with switched 12v...you can leave tha interrupt, power antenna & illumination wires un hooked. you connect tha power wire from tha radio to a switched 12v source...tha yellow(whatever color it is) to a constant 12v source.....you can ground it by jus drilling a screw in a piece of metal near tha radio, or use a bolt that's already there & jus wrap tha wire around tha screw or bolt.
Hope that helps..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse Last edited by Pop's C-10; 04-22-2011 at 06:45 PM. |
04-22-2011, 08:43 PM | #3 | |
04-22-2011, 09:24 PM | #4 |
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse Last edited by Pop's C-10; 04-22-2011 at 09:27 PM. |
04-22-2011, 08:41 PM | #5 | |
audio interrupt is for a cell phone or gps power annt is for the power annt if you don't need these cover them so they don't short out the illumination goes to the dash lighting(gauges) so they'll dim with the gauges lights..( this can if you want ,be put with the ignition power wire but you'll not have any dimming) the batt+ is to go to a non switched power as this it what powers the radios memory [station pre sets/bass treble setting/eq setting/balance/fader/etc) the ign + is for switched power ,so the radio goes off when you shut off the car.. hope this helps Last edited by stich626; 04-22-2011 at 08:46 PM. |
04-26-2011, 06:48 PM | #6 |
needs more $$$
Got any pics of the covair? I've always wanted one...
1970 2wd Blazer |
