Old 04-22-2011, 10:09 PM   #1
1971k567cam
1971k567cam's Avatar
fuel tank to small
So I was thinking that I would like to put a bigger fuel tank in blazer this one seams to run out very quick. I am in process of building a 383 mpfi engine with a 70r4 set up to put in but have found with carb that fuel goes really quick after 4.10 gears. Would a suburban tank fit in a blazer? Same sender? Thanks for all your help and ideas
1971k567cam is offline   Reply With Quote
Old 04-26-2011, 12:08 AM   #2
70cst
70cst's Avatar
Re: fuel tank to small
ttt for assistance
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-26-2011, 09:16 AM   #3
turp mcspray
turp mcspray's Avatar
I put a 31 gal tank from a 73 up blazer, in my 72. I moved the rear crossmember back. And used the front crossmember from the 73 up tank. Sender is still o-90 ohms. I also relocated the filler neck to the driver side, so I could attach it to the original filler.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 04-26-2011, 07:20 PM   #4
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
If I put a bigger tank in my jimmy then my wallet would be to small.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 04-26-2011, 07:25 PM   #5
cleszkie
cleszkie's Avatar
I put in a 40 gallon tank made by NMP (Northwest Metal Products). Cost about $300, but that was like 15 years ago. Came with fuel sender that works with stock gage. When I fill that thing up, the Blazer squats!
cleszkie is offline   Reply With Quote
Old 04-26-2011, 11:27 PM   #6
themb2g
that same tank from NWMP.com Is about $700 now. but it is 37 gallons, which is nice. I am thinking of getting one, but i need to have them install an intank pump capable of 65 psi for efi into my lq4.
themb2g is offline   Reply With Quote
Old 10-24-2011, 05:45 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
Bringing up an old thread.... contemplating the LSx upgrade...
I was looking on www.rockauto.com at 1991 Suburban 40 gallon tanks. They use an in tank pump to support the 454 TBI motors, but not sure of the pressure the pump puts out. You can always upgrade to a Walbro pump. They list dimensions for the 31 Gallon andthe 40 Gallon tanks. You can get a 40 gallon tank and sending unit with pump for $230 plus S&H.... you just need a regulator, probably the C5 Corvette regulator would work well....
Has anyone tried to shoe horn the 40 gallon tank under a Blazer?
Rich
1972 K5 Blazer CST Click HERE
Old 10-24-2011, 12:50 PM   #8
Firebirdjones
This subject seems to have popped up alot lately. I too want a larger tank, but I also want an internal fuel pump for the 6.0 swap I did rather than the current external.
I'm really leaning towards a custom aluminum tank. I would rather have the tank hang lower rather than get wider/longer. Or maybe a mix of the two, but I definately don't want to start moving cross members and hacking up the frame, because I'm also installing a hidden hitch, so moving the cross member is out of the question really.
Just so you know, LS engines require 55 psi minimum to run properly.
Firebirdjones is offline   Reply With Quote
Old 10-24-2011, 01:10 PM   #9
viking427
Someone over on CK5 just got a NWMP 37 gallon tank and posted some pics of it and their 72 Blazer install. You can clearly see the Blazer's rear crossmember that would need to be moved back or removed trying to wedge a 40 gallon Suburban (1991, EFI, internal pump) tank in there. The burb tank is 35" long x 29" wide x 14" deep. As Turp says he had to move his rear crossmember back just for the Blazer/Burb 31 gallon size (29" x 29" x 13" deep). However, if you're running a class III/IV/V trailer hitch, you could probably remove the rear crossmember altogether, since that would provide the critical crossways frame support, assuming it was installed permanantly.
http://coloradok5.com/forums/showthread.php?t=24981
viking427 is offline   Reply With Quote
Old 10-24-2011, 01:32 PM   #10
Firebirdjones
Looks like that tank installed without moving the cross braces, and I also see a hitch in there as well. Looks like what I want to do will work.
I'm using the hidden hitch from Earlyclassics. I believe it would be a class III more than likely.
Unfortunately some of those guys posting did this swap 10 years ago or so, and someone mentioned these particular gas tanks aren't stocked anymore.
So I'm guessing it's a custom order basis (if you can still get them) or someone has done this more recently??
Old 10-24-2011, 02:18 PM   #11
viking427
Yes the NWMP 37 gallon and Aero 40 gallon (almost identical) are both still produced and have support (parts, install kits etc.). Correct, niether one of those tank will require moving crossmembers since they were specifically designed to fit the early Blazer. Aero actually lists theirs, p/n 1139, as fitting 70-85 Blazer. However, the 31 and 40 gallon GM oem tanks that came in 73+ Blazer and/or Suburban are basically square or rectangular in shape. These oem tanks lack the "drop" at the rear designed into the NWMP & Aero tanks to go under the crossmember, which means the crossmember needs to be moved back when using the larger oem tanks in order to allow them to fit. The attraction of these oem tanks for those doing EFI swaps (besides their extra capacity), is the later ones (88-91?) are setup for fuel injection with the necessary plumbing and in-tank electric pumps. I'm not sure if the sending unit holes in the NWMP or Aero tanks are large enough to drop an electric pump setup in them or not, I would think so.
http://www.aerotanks.com/inventory/1139.html
http://www.nwmp.com/index.php?option...-gmc&Itemid=17
Old 10-24-2011, 09:46 AM   #12
turp mcspray
IIRC, the only dimension that changes with the 40 gal. is the length from front to back. I don't think there is any way it will fit in a blazer. With mine I moved the rear crossmember further back, and the front of the 31gal. tank, goes right up to the differential.
Turp Mcspray
Old 10-24-2011, 02:31 PM   #13
AJs72K5
AJs72K5's Avatar
Not entirely true. There are several folks around that have put a NWMP tank into a K5. Burt4x4 on this board is currently running one. Was a direct bolt in, if I recall.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 10-24-2011, 02:36 PM   #14
viking427
He's talking about the factory 31 and 40 gallon tanks GM put in the later Blazers and Burbs
Old 10-24-2011, 08:16 PM   #15
turp mcspray
Here are a couple pics of a 73 up, tank installed. The rear crossmember was moved back 8". It's not a great shot of the front of the tank, but it goes pretty much up to the rear diff. I have seen this install done on a non lifted truck, and if you can remove the diff cover with out raising the rear of the truck, it isn't by much.
Turp Mcspray
Old 10-24-2011, 09:15 PM   #16
NW_Ryker
I have a NWMP fuel tank in my truck, and the trailer hitch had to be removed to install it.
NW_Ryker is offline   Reply With Quote
Old 10-24-2011, 10:20 PM   #17
viking427
Hmmm, that 31 gallon Blaz/Burb tank does look tight in there, doesn't look like there's an extra 6" of frame left on the backside that the 40 gallon Suburban tank would need, regardless of the crossmember. It does look original though, I like the factory skid plate setup.
