03-06-2009, 09:42 AM | #1 |
Hollister, CA.
HOW TO: Split the brake lines (many have asked)
Here's a short write up on how I split the lines on my truck.
This is perfect for the person who wants to have a "split" system, but is not ready or cannot afford disc brake conversion right away. Our trucks utilize a single line coming out of the stock master cylinder (whether manual or power). This single line is Tee'd off at the LF wheel, then again at the RF wheel. From there, it runs to the rear of the truck which it feeds the rear brakes..where it is Tee'd again for the L and R rear wheels. This system is fine...and has been for years. Although, as vehicles get older and related brake parts wear, you run the risk of looseing your brakes COMPLETELY if you blow a line, a wheel-cylinder, or even if the master goes out !!! Of course this does not cure problems elsewhere in your system, which should be checked and replaced as neccesary. That could be scary or even DEADLY !! I would sure hate to have an accident and injure one of my family members, or anyone else on the road for that matter. So until I'm ready to do a full resto on my truck, I decide to upgrade the brake system using readily available, inexpensive off the shelf parts. HERE WE GO: The first thing to do is remove the stock master, along with the single line down to the first Tee. The one on the left is the stock (obviously) Now the one the right is a NEW drum/drum master I picked up at Kragens for under $30...I asked for a 67-70 IMPALA drum/drum car...non P/B....Can't beat the price !!! - - You then need to pick up some line and fittings. You can purchase straight lengths of line with end on them, or pick up the line and fittings seperate. I went to RoyalBrass (a local fitting store) and picked all the fittings and the line I needed to do the conversion... - - - Two adapter fittings for the Master..four Inverted..one plug...and a union... The master bolted up NICE - - - - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by augie; 04-23-2011 at 01:17 AM. |
03-06-2009, 09:43 AM | #2 |
Hollister, CA.
Re: HOW TO: Split the brake lines (many have asked)
Here's a shot at the R/F tee fitting....Located behind the crossmember under the frame rail:
- - Disconnect the rear line...and plug the tee...then install a union on the rear line.... - - - - Now, it's time to begin the bending. You will need a good quality bender to bend the lines. The black sharpie marks are guide marks used by me in conjuction with my bender. It has markings on the handle that you transfer to the tube, in order to determine where to start the bend.....Now start bending !!! - - - - - - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by augie; 04-23-2011 at 01:19 AM. |
03-06-2009, 09:45 AM | #3 |
Hollister, CA.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by augie; 04-23-2011 at 01:20 AM. |
03-06-2009, 09:47 AM | #4 |
Hollister, CA.
These reference pics show clearance of lines using a SB and Huggers:
- - - - - The new crossmember line can be installed with engine installed...these shot were taken when engine was out. The front feed line was installed after the engine was in: - - - The second line (pictured above) was ran down to the original first tee. The push rod was also modified for this MC. Pics to follow...
03-23-2009, 10:24 PM | #5 |
Can some one explain what had to be done to the original push rod. I gathered all the parts to do this but dont want to break down the system until I know for sure what is involved in making the master cylinder work correctly. Thanks
03-23-2009, 11:20 PM | #6 |
Hollister, CA.
Sorry I haven't had a chance to finish this topic up, and make it a sticky....I haven't been on in a while. My pops is in the ICU and not doing so good.
If I remember correctly, all I had to do was loosen the jam-nut and extend slightly to achieve a slight endplay. Additional pics will follow shorty, with a parts list, as with some editing and then it get STUCK !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
05-12-2009, 10:13 PM | #7 |
Thought I should add that on my 1962 GMC with the Dana 44 rear end, where the front 1/4" line tees off to the rear, my line to the rear is a 3/16" line. I wasn't sure if it was the same thread on the 3/16" line as the 1/4" inverted flare fittings (possible, didn't get to check), but I picked up a 3/16" adapter bushing in addition to the two other adapter bushings for the masters.
One was a 5/16" to 1/4" adapter, and the other one was 9/16"-18 to 1/4" I think. This fit my new remanufactured 1967 Chevy/GMC truck 1-1/8" bore drum/drum master cylinder. Got one piece of 60" line as I think I read someone else saying they needed about 51", and then I got a second piece 40" long to replace the line from the old master down to the first tee by the left front wheel. This piece will need to be longer on mine at least, since my 62 manual trans master has the lines out the bottom. The lines came double flared on both ends with the 1/4" inverted flare fittings already on. Advanced Auto Parts and Car Quest both had drawers full of these adapters, so it makes it pretty simple. Take your master with you and bush it down to 1/4". what I got: *60" of 1/4" line w/two inverted flare 1/4" fittings (for new rear line) *40" of 1/4" line w/two inverted flare 1/4" fittings (for front line, from new location on side of new master to tee at left front junction - might make do with a 30") *1/4" inv. flare coupling or union *1/4" plug *5/16" tube x 1/4" tube adapter bushing for master rear line (check your master) *9/16"-18 thread to 1/4" tube adapter bushing for master front line (check your master) DORMAN Part # M66787 More Info {First Stop #18008616, 3912128, 3941939, 5458531, 5458905} w/Power Brakes; Bore = 1-1/8"; RWD; Bendix; Exc. 11000 Lb Rear Axle$50.79 On the bushing sizes, I believe the thread sizes in the master are 9/16"x18 and 1/2"x20, but I listed the way Advance Auto Parts has them on my receipt. Also it should be noted that I am replacing a 1-1/8" bore master with a 1-1/8" bore master. I am adding a power booster (the old style that uses these deep bore masters same as a manual master's bore). I read in one article that said if you are switching over to power, you can get away with running one size larger master cylinder bore diameter. So I could have ran 1-1/4", but I hope to reuse this master minus the front residual valve for swapping to power discs, which would have used a 1-1/8" bore power brake master. Did I confuse you yet? I'm also dealing with a 60-62, so I have to get rid of my stock clutch/brake combo master and install a separate clutch master in the stock location, and using a power booster and custom made booster bracket to give me the room to run the clutch master in the stock clutch master location. See my other recent thread on this topic. I have not fit all this up yet, but based on Cheif's writeup, I think all of this is correct.
Chuck in Ohio *1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end *1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project *Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc |
08-15-2009, 02:33 PM | #8 |
John you did have to drill new holes for the master right?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
08-15-2009, 02:44 PM | #9 |
Hollister, CA.
No, not at all...it bolted right up.
Course, thats cause us 63 and up guys are special !
08-25-2009, 09:11 PM | #10 |
1961 crewcab
2 questions..
could Isee a pic of your tubing bender? not the belly the actual bender. and, does this kind of system need a proportioning valve? |
08-26-2009, 09:15 AM | #11 |
Hollister, CA.
It looks like this one....I also have the Matco double flaring kit.
- - Using a drum/drum master (two port Impala) you do not need a prop valve. - -
10-02-2009, 07:16 AM | #12 |
Hi Chief, Great write up. I am currently doing this on my '64. Got some questions. Did your old master have a 1" bore? What about the new one? My '64 is 1". The master at O'reilly's for a '70 Impala, drum/drum, no power, was 1 1/8. The master with a 1" bore was listed for discs with power. I believe I have read on other posts that using 1 1/8" master will make the brakes feel spongy. Do I have that right? Is the 1" bore the one to go with? I wonder if the parts store has it listed wrong? Thanks in advance for any help from anyone that can.
Eugene
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
10-02-2009, 08:50 AM | #13 |
Hollister, CA.
Not exactly sure, I'd have to research that.
I went with one from a '67 Impala. At the time, my buddys 67 Impala was in my shop, so I compared them. The brakes on the black truck worked great...full pressure and never spongy. My new truck will recieve the same treatment, although this one will get 6-lugs discs.
12-23-2009, 09:07 PM | #14 |
dug this one up cause I really want to do this. Question though, can I just buy new pre-bent lines from the Truck shop and make it a full on bolt in affair? I dont mind spending the extra cash since I dont have the time/space to fab up the lines myself.
12-24-2009, 02:41 PM | #15 |
the lines are real easy to bend, in fact, if just keeping the 4 whl drums, you don't even need to cut and flare the lines if you buy the right lengths, see my posts on this and it probably gives you the lengths I used. When doing discs up front, you will need a lot more plumbing for the prop valve and all.
01-04-2010, 05:43 PM | #16 |
QUOTE: The push rod was also modified for this MC.
Any more info on this. I feel the need for a dual MC for safety reasons. i have a 61 c10 and i think i have every thing i need to complete the master swap. im useing a master i bought from autozone for $15 bucks it is from a 67 c10. just have a few questions first thanks 1. do i have to drill new holes for this master 2. what mods are needed for push rod(pics please) 3.what is everyone useing for brake lines (they said n/a at auto zone) mine are a little soft. thanks for all the info
61 step/long bed SBW(SOLD) NEED A NEW PROJECT |
01-05-2010, 09:38 AM | #17 | |
Hollister, CA.
2) The push rod had to be extended. I sold my black truck, and for some reason never got pics of the rod. I cut the stock rod in half, then welded more rod between the two. I still retained the adjuster part of the rod. Once the master is installed, and the pedal is in it's released position (check your bump stops too) you want the tip of the rod to be about 1/16" to 1/8" max away from the piston. 3) I purchased some straight pieces of line from my local fittings store (or a speed shop).....it came with ends. Bent them and double flared them myself.
01-06-2010, 01:00 AM | #18 | |
60-66 Nut
On the '60-'62's you will need to drill holes to bolt up a '63 and newer master cylinder
01-07-2010, 07:55 AM | #19 | |
Hollister, CA.
Keep assuming people have the 63 and up...
04-22-2011, 08:44 PM | #20 |
Don't know if it's cool to bring this back up but I'm thinking that I really want to do this when I put my truck back together in a week or two. I get the concept with blocking off the one T and the split but where I'm lost is the push rod... anybody have clever ideas on how to make a good pushrod? Would a pushrod like this work? Any thoughts on where to get the parts it does?
Thanks! Barry |
04-22-2011, 10:03 PM | #21 |
You can use your old master cylinder's push rod. If it is addjustable then addjust it out,if it is not you can have some one cut it and weld it. Or you can get an addustable one from speedway or a used one from the wreckers.
The push rod that is in the link will not work I used that type on my clutch master it had a pushrod with a threded end.
03-06-2009, 06:49 PM | #22 | |
Hollister, CA.
Sure can...and plan on it once I get this 'How-to' thread complete
I have about that as well if not more !!!
03-06-2009, 08:37 PM | #23 |
Lowered in Cleveland
That is a very nice write-up with pictures, just wondering, what is the size of the tubing you used and what was the size of the existing tubing. You made it look easy, thanks for sharing.
03-06-2009, 08:59 PM | #24 |
Hollister, CA.
I used the stock size tube which was 1/4".
Ask away all the questions you fellas might have....I will try to answer everything in this thread....as I will make a new one right before I "sticky" it.
12-24-2009, 09:11 AM | #25 |
The Beach Cruiser
Any more info on this. I feel the need for a dual MC for safety reasons. Nice work and write up.
1999 Silverado DD 1966 Panel Truck 2003 Harley Road Glide 1967 Schwinn Tandem Single Speed |
