Old 04-23-2011, 12:28 PM   #1
clean68sbc
68c10 swaping to disc need help on reading vin on donor truck for yr of spindles
I got the spindles and tie rods of i believ a 70-73c10 to put on my68 cant get right balljoints vin of donor truck is cs141f833030 just need to know exact yr to order correct balljoints please help.
clean68sbc is offline   Reply With Quote
Old 04-23-2011, 12:35 PM   #2
truknut
truknut's Avatar
Re: 68c10 swaping to disc need help on reading vin on donor truck for yr of spindles
I usely use gmcpauls, but his site is under construction.
1990 Chevy Silverado (My DD)
1978 Chevy Bonanza LWB (My LWB to SWB 1 day project)
2015 Hyundai Sonata (Wife's DD)
truknut is offline   Reply With Quote
Old 04-23-2011, 02:09 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
70 spindles would be drum brakes. 71-87 spindles are disc brakes and are the same except for the upper ball joint. Buy a 72 and a 73 ball joint and see which fits. Then you'll know for sure. Also, if the donor truck looked similar to yours then 71-72, because 73 and newer are a whole different body style.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 04-23-2011, 04:11 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
the VIN you show off the donor truck is a 71....go here to decode
http://outintheshop.com/vin_decode.html
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-25-2011, 04:56 PM   #5
clean68sbc
thanks guys i just coulndt seem to decode it n i took pics of the balljoints n the tops deffinately look different then on my 68 n the bottoms are just a little bit different shank size so i just need to order 71 uppers then is wut u are saying
Old 04-25-2011, 09:39 PM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
did you grab the center link off the donor too or are you using the 68 one?
Geoff with a G
Old 04-26-2011, 01:28 PM   #7
clean68sbc
i grabed the tie rods but not the actual center piece do i need it?
Old 04-26-2011, 04:46 PM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
yes....the centerlink is different for 67-70 and 71/72 trucks....or you'll have to use different inner and outer tie rods and a modified adjusting sleeve for the 68 centerlink....i personally would try to stay with all the same stuff, because I would end up forgetting what I did
Geoff with a G
Old 04-27-2011, 11:07 AM   #9
clean68sbc
i can always go back n get the center link from the truck at the junkyard anything else i needso i dont have to make more trips the way gas prices are haha? and will the centerlink bolt on to the 68 steering components i already have?
Old 04-27-2011, 11:28 AM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
In short, no the 68 stuff will not bolt up to the 71/72 steering centerlink.....
I think it would be best for you to read through this thread here....http://67-72chevytrucks.com/vboard/s...68&postcount=4
It was put together by one of the suspension gurus on this site....hopefully it'll answer all of your questions, but if not, contact him for help
Geoff with a G
Old 04-27-2011, 03:48 PM   #11
clean68sbc
would any of u guys kno wher i can get the tie rod conversion sleeve talked about on here to make the thread situation work?
Old 04-27-2011, 03:51 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
CPP and POL (Performance OnLine) sell them.
(approx. $50/pr.)
http://www.performanceonline.com/196...-SLEEVES-PAIR/
Use the "drop down" tab to find the conversion sleeves.
Keith
Convert to disc brakes.
Old 04-28-2011, 12:03 PM   #13
clean68sbc
thank you so if i order these i can use the 68 inners and the 71 outers i pulled off the donor truck correct?
Old 04-28-2011, 08:17 PM   #14
clean68sbc
my 71 upper balljoints came in today am i going to need 71 lowers too or will the 68 lowers work?
Old 04-28-2011, 08:19 PM   #15
clean68sbc
ok on the tie rods i ight not need to by the conversion sleeve at all just put the 68 outer on the inside then thread on the 71 outer to it?
Old 04-28-2011, 06:53 PM   #16
lolife99
lolife99's Avatar
Actually you have to move the 68 outers to the inner location.
They are LH thread.
This will allow you to connect them to the 71 outers,... which are RH thread.
Keith
Old 04-28-2011, 08:44 PM   #17
lolife99
lolife99's Avatar
You will need the conversion sleeve.
68 tie rods are 5/8" diameter.
71 tie rods are 11/16" diameter.
Keith
Old 04-28-2011, 08:46 PM   #18
lolife99
lolife99's Avatar
You will need both 71 upper and lower ball joints if your spindles came from a 71.
Keith
Old 04-30-2011, 12:07 PM   #19
clean68sbc
ok thanks so il order lower balljoints td and wut are the conversion sleeves exactly called because on the websit it just states adjusting sleeve?
Old 05-02-2011, 08:45 PM   #20
clean68sbc
Question Re: 68c10 swaping to disc need help on reading vin on donor truck for yr of spindles
please help i got everything for the disc brake swap except tie rod sleeves the websites u stated have just regular one the same size thread n both ends do i have tocall them or is there specific onei cannot seem to find????
Old 05-02-2011, 09:14 PM   #21
lolife99
lolife99's Avatar
Part number HPA6570.
Keith
Old 05-04-2011, 04:21 PM   #22
clean68sbc
Thumbs up Re: 68c10 swaping to disc need help on reading vin on donor truck for yr of spindles
thank you guys this is a great sight
Old 05-04-2011, 04:23 PM   #23
clean68sbc
ok so those ones will work with the 71 tie rods even tho it says 73 because its the conversion
Old 05-04-2011, 09:13 PM   #24
lolife99
lolife99's Avatar
YES.
'71 tie rods are the same 11/16" diameter as the 73-87 tie rods.
I have '71-'72 spindles on my red '69 swb with these exact tie rod sleeves from Performance Online.
Keith
Old 05-06-2011, 04:14 PM   #25
clean68sbc
thank you for your help guys everything is order will post pics hen i put it all on
