Old 04-23-2011, 01:52 PM   #1
chevymotocross
chevymotocross's Avatar
How much weight have you hauled in your lowered truck?
I have a 6'' rear drop with a bolt-in C-Notch. I haven't hauled anything heavy in it since the drop, but I am considering picking up Mulch soon. I've hauled mulch before with this truck, at stock height, and the rear squatted pretty far.
It has a 5 spring leaf pack. Nothing as far as exhaust pipes or cables hang low. Rear tires are 275/60/15.
Think I can safely haul the mulch?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 04-23-2011, 01:58 PM   #2
hotrodhomi
hotrodhomi's Avatar
Re: How much weight have you hauled in your lowered truck?
i put 1500 lbs of sand in my swb, but it bottomed out over bumps.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-23-2011, 04:13 PM   #3
J_PEPIN87
J_PEPIN87's Avatar
my truck has 6in. drop in the back with a flip kit and bolt in c notch.i hauled the big block thats in it now and it would bottom out over bumps.
J_PEPIN87 is offline   Reply With Quote
Old 04-23-2011, 06:46 PM   #4
chevymotocross
Sounds like I might pass on hauling the mulch. I'm sure a bed full of mulch weighs more than the big block you hauled.
Here is a photo of hauling mulch before the lowering kit
Old 04-23-2011, 06:56 PM   #5
lakeroadster
Frame Notch Based On Strength
lakeroadster is offline   Reply With Quote
Old 04-23-2011, 07:07 PM   #6
chevymotocross
Originally Posted by lakeroadster View Post
I think I'll borrow my friend's truck lol
Old 04-23-2011, 08:24 PM   #7
78 Chevyrado
What kind of wheels are those? I like them a lot. They look good!
78 Chevyrado is offline   Reply With Quote
Old 04-24-2011, 12:40 AM   #8
chevymotocross
I just recently removed those and put on factory rally wheels. Not sure of the brand of those old alloys.
Old 04-24-2011, 01:12 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
How much mulch do you need? Around here they will deliver if you buy a minimum of 4-5 yards.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-24-2011, 09:12 AM   #10
mentlmidget
Interestingly enough, I have hauled 3/4 stone that covered the wheel wells, bags of mulch to the top of the bed and yes it bottomed out the truck with springs. Oddly enough, the used truck didn't have it's helper springs. I used 1/4 inch wall, 2x2 square tubing welded to the top of the frame, 3/16 plate on the outside and inside of the frame, and boxed in the knotch with pieces of 1/4 plate steel. With 4 springs, I suppose the position of the springs helped to disperse the weight more evenly across the frame at the spring perches. Last week I finally put the bags on. I don't have plans of hauling that kind of weight anymore. Looking for an honest opinion, how does it look now? I think the by removing the leafs, the weight is now going to be put more on the bag perches.
I couldn't figure out how to get bigger images.
mentlmidget is offline   Reply With Quote
Old 04-24-2011, 09:16 AM   #11
mentlmidget
bigger images...maybe
hmm...worked this time
Old 04-24-2011, 09:41 AM   #12
lakeroadster
Originally Posted by mentlmidget View Post
.... I used 1/4 inch wall, 2x2 square tubing welded to the top of the frame, 3/16 plate on the outside and inside of the frame, and boxed in the knotch with pieces of 1/4 plate steel...... Last week I finally put the bags on. I don't have plans of hauling that kind of weight anymore. Looking for an honest opinion, how does it look now? I think the by removing the leafs, the weight is now going to be put more on the bag perches.
Nice job on the notch. Adding the truss (2" tubing) and boxing plates makes for a stronger notch. Now you have a cool stance, and can still use your truck to haul stuff!
Looks good.
In regards to bags versus leaf springs, the leaf springs distributed half the weight ahead of the notch and half behind the notch. With bags its all behind the notch. That means the air bags will stress the notch area of the frame more than the leaf spring set-up did.
But, again, with the way you trussed and boxed the notch it is strong, likely not as strong as stock though due to reduced section height above the notch.
John
Summary
If you want the frame to be as strong as stock and you want a frame notch deeper than the 2" there is simply no substitute for adding some sort of truss structure, or replacing the frame section with another structural member that has the same or greater section height as the original frame.
Old 04-25-2011, 12:35 AM   #13
lilpoindexter
lilpoindexter's Avatar
HOLY SMOKES....that's a helluva notch...It's probably stronger than stock.
lilpoindexter is offline   Reply With Quote
Old 04-25-2011, 11:57 AM   #14
68longhorn
68longhorn's Avatar
My 86swb with one leaf removed to lower it will haul a bed full of mulch but it sits really low! Went to back in my driveway and my bumper hit the apron and stopped me. Other than that she takes it but is just bouncy up front.
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 04-24-2011, 11:33 PM   #15
Jonboy
Slots go on anything!
as far as mulch goes, my '79 with the 4/6 drop but with HD leaves was good for 1 yard before it gave me trouble. I can answer this definitively because I originally loaded 2 yards, and had to circle around and unload about half to get it to be able to move. 1 yard is about level with the bedrails on a shortbed.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-25-2011, 01:51 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
The most I ever hauled in my 77. Not sure how much it weighed, but it's a LOT of steel in those boxes.
Articles-
"Refining Sierra"
Old 04-25-2011, 03:00 PM   #17
96twodoor
96twodoor's Avatar
Ive hauled a 18ft car hauler with an S10 blazer on it ,with a 5/7 drop and a bolt in notch, heres a VERY crappy pic lol
96twodoor is offline   Reply With Quote
Old 04-25-2011, 04:14 PM   #18
chevymotocross
Thanks guys, I'm not going to risk it. I'll borrow my buddies stock trusty 90' c1500. I'll keep my truck for the lighter loads (which usually involves hauling the fun toys, like the dirt bikes )
Old 04-25-2011, 11:16 PM   #19
flamingbig10
6.0 powered square
flamingbig10's Avatar
I hauled my 6.0 with a beltec flip kit, drop shackles, and c -notches with with weak 6 pack springs with over load removed the rear was bottomed out but it was only a 3 mile ride so it did ok
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-26-2011, 01:44 AM   #20
Malo83
Cruzzzn' Vet
Malo83's Avatar
Hauled a load of river rock in my 83 with a flip kit and no C notch and the frame was laying on the axles, luckilly i only had to drive about a mile and a half, it was ruff
Malo83 is offline   Reply With Quote
Old 04-26-2011, 02:59 PM   #21
Low87
been here longer than Liz
Low87's Avatar
I've hauled material for about 150' of wood fence. 4x4s, stringers, pickets & concrete. Rode low and I kept it below 25 mph all the way home, but we made it. No idea on weight.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-26-2011, 10:47 PM   #22
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Washer asnd Dryer Combo.. not too sure the weight, but I have the overloads taken out for the drop. It sits right on the bushings when i get anything of much weight back there tho... I need a suspension overhaul.
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 04-27-2011, 01:41 PM   #23
ds350
How about adding some helper airbags?
ds350 is offline   Reply With Quote
