Old 03-25-2003, 10:16 PM   #1
Dean23
68cst_ss490
Dean23's Avatar
Setting roller rockers
CAn you set up rollers while the engine is running or is it not rtecommended. I have a set installed on my 350, i set them up at zero lash plus 1/4 of a turn to start with.
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 03-25-2003, 10:38 PM   #2
Randy70C-10
Randy70C-10's Avatar
I go one halve of a turn, but a quarter should be fine. I've never tried adjusting them while the engine is running.
Randy70C-10 is offline   Reply With Quote
Old 03-25-2003, 10:40 PM   #3
Dean23
68cst_ss490
Dean23's Avatar
thanks randy, once i get my carb i might fire it on the stand just so I can here it run. It will be a while before my truck is road ready
Dean
edmonton,canada
a winter wonderland
Old 03-25-2003, 10:46 PM   #4
junkyardjohn
junkyardjohn's Avatar
Thumbs up
I LIKE TO SET UP MY ROCKERS (BOTH TYPES, ROLLER & STAMPED) ON THE STAND, WHILE I'M BUILDING AN ENGINE & DON'T USUALLY HAVE TO READJUST THEM, BUT I HAVE ADJUSTED SEVERAL SETS( ROLLER TIPPED,FULCRUM ROLLER & OF COARSE STAMPED) IN THE TRUCK WITH THE MOTOR RUNNING. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-25-2003, 11:07 PM   #5
mikep
Used to have a truck
mikep's Avatar
I dont like adjusting them with the motor running. Gets oil all over the place and stains the headers even when you use those clips which dont really fit roller rockers anyway . Plus with big cams and exhaust that doesnt quite do much besides take the edge off its hard to tell when they start ticking when you back the adjuster nuts off.
No truck :-(
mikep is offline   Reply With Quote
Old 03-25-2003, 11:12 PM   #6
Dean23
68cst_ss490
Dean23's Avatar
my cam is not overly big, 224 i and 234 e 465 lift on i and 488 on e. gonna get a geare drive next week cause i like how they sound. thanks for the help guys.
Dean
edmonton,canada
a winter wonderland
Old 03-25-2003, 11:26 PM   #7
sam's 72
So tell me in details how to adjust them with engine on the stand. When your talking about zero lash, what are you talking about? Is the piston up at TDC, both valves closed?
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 03-25-2003, 11:30 PM   #8
Dean23
68cst_ss490
Dean23's Avatar
on the cran website they have a page telling you how to adjust them. watch the exhaust valve on the cyl you are adjusting when it just starts to open you set intake. i went until i had no more up and down movement of the pushrod, then 1/4 turn. then turn engine over til exhaust opens and closes and then intake is just about closed and set the ehaust valve.
Dean
edmonton,canada
a winter wonderland
Old 03-25-2003, 11:53 PM   #9
Stroker
Dean thats exactly the way I adjust the valvetrain for the very reasons mikep cited. It's also a good idea to check the geometery and all the valvetrain clearances while you at it.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 03-26-2003, 12:22 AM   #10
bigjimzlll
bigjimzlll's Avatar
I cut the top off an old valve cover..keeps the oil from flying all over..
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-26-2003, 10:33 AM   #11
crazy longhorn
Fabricate till you "puke"
I set mine running, & use a "windowed" set of stock covers as BigJim mentioned. As long as the eng is idling, the oil stays where it belongs.......buzz the throttle, & that SB will oil the garage wall tho! good luck,crazyL
crazy longhorn is offline   Reply With Quote
Old 03-26-2003, 11:13 AM   #12
Randy70C-10
Sam
Zero lash is when you are at TDC (compression stroke) both valves are closed and you have tightened the rocker just enough so that there is no up or down movement of the rocker. Another cool way to find zero lash is to spin the pushrod with your fingers while tightening the rocker nut. As soon as you start to feel some tension, you are at zero lash.
Old 03-26-2003, 11:44 AM   #13
mikep
mikep's Avatar
The TDC method doesnt work well with long duration cams. The one outlined on the crane cams website works a lot better.
No truck :-(
Old 03-26-2003, 11:49 AM   #14
Randy70C-10
That's why I have a bench grinder. j/k
