Old 04-24-2011, 09:45 AM   #1
bitchin85
bitchin85's Avatar
body lift
My buddy has an 84 c20 2wd. He has 33s on it and they barely fitand would like some more clearance. Would I run into any problems doing a 1 inch body lift with a hockey puck on every mount? I know its been done before but what all else has to be changed? All longer bolts id imagine, gas giller neck, what about the fan shroud and the shift linkage? Itsits got a turbo 400.any other thoughts would be great thanks
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 04-24-2011, 12:47 PM   #2
VegasBruce
VegasBruce's Avatar
Re: body lift
1" is no big deal. When I did my Blazer, the only thing I had to change was lengthen the clutch rod. I wouldn't use hockey pucks though. ORD makes a 1" lift that is purpose built.
http://www.offroaddesign.com/catalog/oneinchlift.htm
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline   Reply With Quote
Old 04-24-2011, 04:25 PM   #3
bitchin85
bitchin85's Avatar
Re: body lift
The truck is a beater and he already has the hockey pucks. So there's nothing ill have to modify then?
Old 04-24-2011, 08:50 PM   #4
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: body lift
You should have enough on the trans linkage to just be able to loosen the adjusting bolt and re-tighten it after it is lifted. Probably only have to do the same with the fuel filler neck. If you have more than one inch clearance on the fan and shroud, you should be okay. If not, you may have to cut the shroud a bit. One inch is not much. The bumpers will sit lower of course, and if that bothers him, you can fab some brackets, but one inch should not look too weird.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 04-24-2011, 10:18 PM   #5
bitchin85
bitchin85's Avatar
Re: body lift
we got the bumpers figured out were going to extend the front about 3/8 of an inch so when the body goes up an inch that metal piece behind the bumper will be flush with the top of the bumper.. might look funny but whatever.. and the back bumper will stay how it is. if we dont like how the bumpers look, were more then capable of making brackets.
where did you guys get your bolts? forthe bed did you just use longer boltscrom the hardware or what? or will they be long enough? and what about the cab and front clip bolts? thanks again guys
Old 04-24-2011, 10:43 PM   #6
dmartin1
dmartin1's Avatar
Re: body lift
on my 3" body lift i took the old bolts,one of each size and went to the hardware store and got new bolts exactly 3" longer then the existing ones,with washers n such.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
