Old 03-25-2003, 11:34 PM   #1
red72chevy
Unhappy hear a squeek when reversing
here's my problem,
when my truck is engaged in reverse and goin backward i hear a squeek. its horrible, and it isnt constant, i sounds like its rotating cause it goes faster then slower. is it my U-joint or what???? it also does it when i downshift from drive to 2nd (auto tranny). whats the deal? any help would be appreciated cause im a dumb 19 year old.
1972 chevy p/u longbed-grandpa's first new truck
350-72 impala engine donor (6oK miles, honned, new rings, new cam, like new)
edelbrock 600cfm carb
high rise polished intake
flowmaster exhaust
350 turbo tranny
cragar s/s rims
viper red
red72chevy is offline   Reply With Quote
Old 03-25-2003, 11:46 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
You can't be that dumb. You're smart enough to know you have a problem, and smart enough to ask for help.
My first check would be the u-joints. Crawl underneath and stick a long screwdriver or rod through the joint and see if there is any slack in the joint. Works best if you're parked on a level surface so there isn't any load on the driveshaft.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-26-2003, 12:08 AM   #3
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
my money is on the u joints. that or you are squishing a lot of mice!
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 03-26-2003, 01:59 AM   #4
68speedalert
Semi-Senior Member
68speedalert's Avatar
More important than looking for play in the ujoints, take a good flashight and look for rust coming from out of the caps.
BTW, put the trans in neutral and set the parking brake & block a wheel before checking for looseness.
You did hear the part about the block, right?
Steve
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 03-26-2003, 02:04 AM   #5
SteveNix
Sounds like a U joint to me. Check the caps
Bart, a woman is like beer. They look good, they smell good, and you'd step over your own mother just to get one! --Homer Simpson
SteveNix is offline   Reply With Quote
Old 03-26-2003, 02:05 AM   #6
SteveNix
my mistake. 68speedalert just said that.
Old 03-26-2003, 02:39 AM   #7
Hooter
My other Love
Hooter's Avatar
could be a bad steady bearing too
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 03-26-2003, 10:40 AM   #8
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I'd bet on center support bearing if its a 2 piece shaft. If not U-Joints
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 03-26-2003, 12:52 PM   #9
Lippyp
English Chevy Owner
Lippyp's Avatar
As a start I'd take a grease gun under there whilst checking the parts mentioned above and grease any grease nipples you can find (well this is what we call them in the UK!) you find, may at least stop the noise and slow down any further deterioration.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-26-2003, 02:26 PM   #10
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
I greased all my nipples yesterday! And I would indeed lube while you are under there. Where are you from red72?
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 03-26-2003, 09:03 PM   #11
red72chevy
thanks guys, i will do what ya'll said. im from southern indiana.
